| Ventas Comerciales Todo tipo de venta que tenga caracter comercial.(Solo Vendedores registrados) |
Herramientas |
#1 |
Brand: MSD Ignition
Product Line: MSD Blaster 2 Ignition Coils Part Type: Ignition Coils Part Number: MSD-8202 Coil Wire Attachment: Female/Socket Coil Style: Canister Primary Resistance: 0.700 ohms Coil Internal Construction: Oil-filled Coil Color: Red Maximum Voltage: 45,000 V Turns Ratio: 100:1 Secondary Resistance: 4.70K ohms Inductance: 8.0 mH Peak Current: 140 mA Spark Duration: 350 uS Mounting Bracket Included: No Coil Wire Included: No Ballast Resistor Included: No Coil Shape: Round Diameter (in): 2.125 in. Height (in): 6.000 in. Valor $45.000 ![]() Tengo tambien la resistencia MSD que se utiliza cuando el encendido es con platinos. ![]() Valor $10.000 Última edición por TheUser4x4 fecha: 18-03-2009 a las 01:43:55 |
