Antiguo 19-03-2009, 23:10:04   #1
The Varas
Predeterminado electroventilador FLEX-A-LITE
electorvenilador s-blade 16" marca flex-a-lite (u.s.a.) nºd.p.-#398
le falta un soporte
$95000
The Varas está offline   Responder Con Cita
Antiguo 20-03-2009, 23:12:40   #2
The Varas
Predeterminado Re: electroventilador FLEX-A-LITE
un poco mas limpio
Antiguo 22-03-2009, 00:31:11   #3
The Varas
especificaciones
Part Number: FLX-398
Maximum Fan CFM: 2,500 cfm
Fan Quantity: Single
Fan Diameter (in): 16.000 in.
Height (in): 16.625 in.
Width (in): 15.750 in.
Thickness (in): 4.000 in.
Number of Blades: 8 blades
Maximum Fan RPM: 2,380 rpm
Blade Material: Plastic
Blade Color: Black
Shroud Color: Black
Shroud Material: Glass-reinforced nylon
Amp Draw: 17.00 amps
Quantity: Sold individually.
Notes: This is a reversible fan that can be used as a pusher or a puller.
Electric Fan, Single, 16 in. Diameter, Reversible, 2,500 cfm, Black, Plastic, Each
S-Blades mean power and efficiency.
The swoopy, highly curved scimitar blades in Flex-a-lite's Syclone S-Blade electric fans mean that they're very quiet and efficient. What's more, they can recover up to 17 HP and 20 ft.-lbs. of torque that are stolen by typical belt-driven fans. Syclones can be used as primary or auxiliary fans, and they're reversible, too. So they can push or pull the air, and lots of it--up to 2,500 cfm--while drawing just 17 amps. These fans mount through the radiator core, and come with rugged nylon shrouds engineered to withstand high temperatures.
Antiguo 27-03-2009, 21:22:26   #4
The Varas
todavia en venta
Antiguo 30-03-2009, 14:38:24   #5
The Varas
ahora a 90000 $
Antiguo 08-04-2009, 00:35:38   #6
The Varas
si todavia se vende
Antiguo 14-04-2009, 22:03:53   #7
The Varas
85000 lukas
Antiguo 15-04-2009, 11:04:11   #8
Héctor Reyes
Enviar un mensaje a través de AIM a Héctor Reyes
Hola ... Se Puede Instalar Por El Frente Del Radiador ???
Héctor Reyes está offline   Responder Con Cita
Antiguo 15-04-2009, 12:07:52   #9
Juan Sepúlveda G.
En la caja dice que puede funcionar en ambos sentidos, aspirando y tirando.
Filete de electro y a buen precio
Juan Sepúlveda G. está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 19:10:32.
