Antiguo 20-04-2009, 01:35:37   #1
JOTE
Predeterminado Nueva Axial Rtc
Acá va lo que nuevo de Axial, básicamente es la RTR mejorada.
AX10 SCORPION RTC (READY-TO-CRAWL)
Based upon the award winning AX10 Scorpion - KIT!
FEATURES
• Complete Ready-to-Crawl (RTC) out of the box
• 4 Wheel Drive (4WD)
• Mount a standard stick pack to get up and running quickly, or use the included upper link plate to mount smaller batteries lower in the chassis for improved crawling performance
• 55T electric motor: tear up the terrain in-door or out-doors. Easy Operation: no tuning, no fuel, no loud exhaust noise. Just plug’n'go!
• 14T pinion paired with an 87T spur gear gives you a decent amount of wheel speed and great low-end torque.
• True beadlocks: no messy glue
• Hi-quality composite plastic and metals
• Durable (ESC) Electronic Speed Controller: Hi-quality durable forward and reverse speed controller.
• Hi-torque Metal Gear Servo help hold your line when rock crawling
• Solid rear axle lockouts improve ground clearance when crawling
• Slipper clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain.
• Aluminum chassis plates with a molded nylon skid plate provide a solid and rigid chassis
• Ultra compact and lightweight transmission
• Fully locked differentials for more traction when rock climbing!
• Full ball bearings
• Overall gear ratio range from 15:1 to 74:1
• Transmission: 2.6:1; center mounted
• Differentials: front - gear differential; rear - locked (spool)
• Transmission: single-speed
• Tires: Pro-Line Hammers® with Pro-Line® Memory Foams
• Wheels: Axial 2.2 8 hole beadlocks (satin chrome)
• Suspension: 3 Link
• Drive Shafts: universal front and rear
ALL NEW SHOCKS
• 72-103mm shock length, helps lower the center of gravity
• Threaded shock body for easier pre-load adjustments
• 3.5mm shock shaft reduces lateral movement
• Cartridge style bottom helps reduce lateral movement while providing a better steal for less leakage
• Silicone diaphragm provides more consistent feel and better seal to prevent leakage
• Silicone bushing in cap holds shock in place while allowing freedom of movement to prevent binding and prevents the shock cap from popping off
CHASSIS
• Wheelbase: 316mm~332mm (12.4”~13”)
• Width: 254mm (10”)
• Height: 156mm (6.125”)
• Weight: 1588g (3.5 lbs)
• Articulation: 70°
• Ground Clearance: 68mm (2.7”)
ELECTRONICS
• Radio: 2 Channel
• Servos: 1 hi-torque metal gear (standard size)
• Forward/Reverse ESC
• Motor: 55T 540/550 Size
Antiguo 20-04-2009, 01:44:33   #2
fango
Predeterminado Re: Nueva Axial Rtc
MMM osea es practicamente casi la misma mia.. o la que era mia anteriormente stock..? viene con embrague,amortiguadores mas largos, etc etc.. es buena mquina..
Alexis Miño
TEAM MASTERTRACK
Antiguo 23-04-2009, 12:32:56   #3
Loly Pop
Avatar de Loly Pop
el precio? esta a la venta aca o solo importacion? linda makina
Loly Pop está offline   Responder Con Cita
Antiguo 23-04-2009, 13:02:37   #4
JOTE
Empezado por Loly Pop Ver Mensaje
Ni idea, no sale:
www.axialracing.com
Antiguo 24-04-2009, 18:23:59   #5
LuisDodge
Edad: 32
Hola jote cmo estas?? mira me akavo de armar de un crawler y me parec q tu tienes upgrades y le pegas a la cuestion o no??
Gracias Salu2
LQS
LuisDodge está offline   Responder Con Cita
Antiguo 24-04-2009, 18:29:04   #6
Loly Pop
Avatar de Loly Pop
Empezado por JOTE Ver Mensaje
Ni idea, no sale:
www.axialracing.com
ok gracias!
Antiguo 24-04-2009, 18:29:27   #7
JOTE
Empezado por LuisDodge Ver Mensaje
Gracias Salu2
LQS
Hola, la verdad no le pego, lo que se, lo he aprendido de Jarogo, Pelao Daza, Matador... ellos te pueden orientar mas.
Pero tienes que definir qué es lo que quieres, Crawler?, Raid? o algo con que puedas hacer de todo un poco, si es así, cambiale el 90 por un 55T y ojalá un ESC con freno, como el Novak Rooster si es que te alcanza la plata
Lo demás, es tener ganas de pasarlo bien.
Llévala mañana al cerro, 0930 por la entrada de Pedro de Valdivia.
Antiguo 24-04-2009, 19:58:09   #8
LuisDodge
Edad: 32
Ahha yo lo decia porque al que se la compre q tb es de twisted me dijo q tu le habias puesto las pilas en el tren delantero para bajar el centro de gravedad q por eso mi axial las tenia ai..
No puedo :S esta deonde pablo en ARC porque el receptor del control estaba soldado adentro y con el prden cambiado..
tu tienes winches para estas cosas??
Salu2 LQS
Antiguo 24-04-2009, 20:02:57   #9
JOTE
Salu2 LQS
A quién se la compraste? para saber de que hablamos....
Que lata lo del receptor...
Winches, tengo 2 nuevos, que no se si ocuparé, pero se que a Pelao le quedan varios
Si te vuelve a fallar la radio, me avisas, tengo una Spektrum DX2 a la venta.
Consultas a jote4x4@gmail.com porfa
La franja horaria es GMT -3. Ahora son las 08:53:24.
