Antiguo 26-08-2009, 11:28:35   #1
Matías del Río
Avatar de Matías del Río
Predeterminado Axial SCX 10 1/10 scale RTR con rueda de repuesto!!!!!
Vieron al nuevo muñeo que saco Axial????
http://www.tcscrawlers.com/Pre-Order...2-p-17878.html
RTR???? Interesante.... ademas es scale y trae hasta rueda de repuesto!!!!
Casi que me tiento, jejejejeje
Pre-Order The following item has not yet been shipped by the manufacturer but we are offering them up for sale as a pre-order. We will ship these to you as soon as possible when they arrive from the manufacturer. Any in stock items ordered with this product will ship now, and a sepereate shipping fee will be charged for the pre-order item that will ship later when the product arrives.
SCX10 TR (Trail Ready)
Complete ready to run out of the box. 4WD. 27T Electric Motor: Tear up the terrain in-door or out-doors. Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go! 20T pinion paired with an 87T spur gear gives you quick acceleration while still allowing for a smooth low end speed range. True Beadlocks: No Messy Glue! Hi-quality Composite Plastic and Metals. 6 LED's: 4 white LED’s for the front and 2 red LED’s for the rear. Electronic Speed Controller (ESC): forward and reverse speed controller. Hi-Torque metal gear servo helps hold your line when rock crawling.
Solid Rear Axle lockouts improve ground clearance and offer a more realistic appearance. Slipper Clutch: Reduces gear wobble for a more efficient drivetrain. Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain. Steel chassis rails with a molded composite plastic cross members provide a solid and rigid chassis. Ultra compact and lightweight transmission. Full Ball bearings. Overall gear ratio range from 15:1 to 74:1. Transmission: 2.6:1; center mounted. Tires: Pro-Line 1.9 Flatirons tires. Wheels: Axial 1.9 8 Hole Beadlocks (Satin Chrome). Suspension: 3 Link. Drive Shafts: Universal front and rear
Chassis Dimensions
a. Wheelbase: 290mm (11.4”)
b. Width: 227mm (9”)
c. Height: 150mm (5.9”)
d. Weight: 2086g (4.6 lbs)
Ground Clearance: 68mm (2.7”)
Body Dimensions
a. Length: 425mm (16.7”)
b. Width without fender flares: 180mm (7.0”)
c. Width with fender flares: 226mm (8.9”)
d. Height: 145mm (5.7”)
Electronics
a. Radio: 2 Channel
b. Servos: 1 Hi-Torque metal gear (Standard Size)
c. Forward/Reverse ESC
d. Motor: 27T 540/550 Size
Required Items
a. (1) 7.2v Stick Pack Battery
b. (8) AA size Batteries
Última edición por Matías del Río fecha: 26-08-2009 a las 11:34:42
Antiguo 26-08-2009, 12:27:27   #2
matador
Edad: 61
Predeterminado Re: Axial SCX 10 1/10 scale RTR con rueda de repuesto!!!!!
yap... me tenté....se viene...se viene...me gustó...
salu2.Matador piedra 'e curanto..
Antiguo 26-08-2009, 12:59:30   #3
matador
Edad: 61
aunque viendo detalles...trae mucho plástico..la jaula...los links..el body es medio burdo en el tema de la cabina (asientos y demases)...las luces son interesantes.... el color del kit es adecuado...trae un motor 27...
eso..
Antiguo 26-08-2009, 13:04:54   #4
Matías del Río
pero como lograste ver los detalles de la cabina?????
Antiguo 26-08-2009, 13:09:06   #5
matador
Edad: 61
en http://www.axialracing.com/ftp/pdfs/...2-I001_web.pdf
es el manual de armado..
Antiguo 26-08-2009, 13:20:21   #6
Thumbs up Re: Axial SCX 10 1/10 scale RTR con rueda de repuesto!!!!!
eso..
Concuerdo con Alberto .. tiene muchos componentes plasticos .. ademas a mi ya no me quedan estacionamientos para bichos nuevos .. estoy o pase el limite .. uno mas es pasaje seguro fuera de la casa .. jejeje
Antiguo 26-08-2009, 13:45:30   #7
Matías del Río
al parecer lo unico bueno es que trae de serie la posibilidad de montar la bareria adelante o atras....
Antiguo 26-08-2009, 14:04:31   #8
fango
uhhh ta bonito..... me encanto el parachoques... es tentador.....
FANGO
TEAM MASTERTRACK
Antiguo 26-08-2009, 14:28:28   #9
JOTE
A mi me gusto... En una de esas, si me alcanza, la traigo.
Antiguo 26-08-2009, 14:40:19   #10
Matías del Río
No esta nada de mala la idea.
Yo la verdad estoy entre este y el venom creeper...... cual sera el definitivo?
La franja horaria es GMT -3. Ahora son las 14:35:07.
