Antiguo 24-06-2010, 00:31:37   #1
tito8
Contactar con tito8 a través de MSN
Thumbs up Gata airjack liquidacion 2 unidades 95.000c/u
EASYLIFT AIRJACK
1 Fabricated Lifting Bag High tenacity Polyester cloth coated both sides with plasticised PVC. Double skin to top and base.
2 Inlet Connector welded to bag Inner mechanical connection of glass reinforced polyamide, overmoulded in PVC.
3 Exhaust Connector Cone Rubber injection moulding
4 Bag Connector/Valve Glass reinforced polyamide moulding.
5 Hose - 6 metres (20 feet) UV resistant EPDM rubber extruded lay-flat tube.
DIMENSIONS
Model Diameter Height Volume Lift Capacity
cm ins cm ins Litres cu.ft. Kilos lbs
ELH04 86 34 70 28 407 14.36 4,000 8,800
http://www.air-jack.com
tito8 está offline   Responder Con Cita
Antiguo 24-06-2010, 00:32:57   #2
tito8
Predeterminado Re: Gata airjack liquidacion 2 unidades 95.000c/u
http://www.air-jack.com/defender_video.htm
La franja horaria es GMT -3. Ahora son las 14:19:09.
