Antiguo 18-09-2010, 00:28:39   #1
Diablo
Predeterminado Preventa de winches, hi-lift y accesorios merchat 4x4
Estimados:
Estamos iniciando la preventa de los productos que estamos trayendo a Chile para 4x4.
La preventa tiene un 25% de decuento y para encargarlos se requiere un abono del 30% y la diferencia se cancela una vez llegado con alguna de las formas de pago que tenemos disponibles.
Los productos en preventa son:
Winche ATV 2000 lbs
Valor Normal $120.000.-
Preventa $90.000.-
Specifications:
  • Performance 12V
  • Rated line pull 2000lb(907kg)
  • Motor 1.0hp
  • Gearing Differential Planetary
  • Gear ratio 153:1
  • Wire rope 5/32" x 25'(4mmx15.2m)
  • Dimensions L x W x H (285 x 105 x 105mm)
  • Drum Diameter 1.25"(31.75mm)
Winche ATV 3500 lbs
Valor Normal $140.000.-
Preventa $119.000.-
Specifications:
  • Rated line pull:3500lbs(1587kgs) Single-line
  • Gear ratio: 153:1
  • Gear train: NGWN type planetary gear transmission
  • Clutch: Turn
  • Motor: Permanent magnet DC 12V motor with 1.3hp output
  • Battery Leads: 0.24" 2 x 6.23 (6mm2 x 1900mm)
  • Motor Leads: 0.24" 2 x 4.26' (6mm2 x 1300mm)
  • Overall Dimension: 12.64"(L)x7.83" (W)x4.72"(H)
WINCHE 4X4 8500 LBS
Valor Normal $320.000.-
Preventa $272.000.-
Specifications:
  • Performance 12VDC / 24VDC
  • Single line rated pull 8500lb(3856kg)
  • Motor 5.5hp/4.0kw,Series Wound
  • Control Remote switch,12ft(3.7m)lead
  • Gear train 3 Stage Planetary
  • Gear reduction ratio 235:1
  • Braking Action Automatic In-The-Drum
  • Drum size Diameter2.5"(63.5mm) Length 8.8"(224mm)
  • Cable 94ft of 5/16" diameter??24m of 8.1mm diameter)
  • Fairlead 4-Way Roller Fairlead
  • Remote Control Included
  • Battery Recommended:650CCA minimum for winching
  • Battery Leads 2 gauge,72"(1.83m)
  • Finish Black/Dark Grey
Winche 4x4 10.000 lbs.
Valor Normal $375.000.-
Preventa $281.250.-
Specifications:
  • Single line rated pull 10000lb(4536kg)
  • Motor 5.6hp/4.2kw,Series Wound
  • Gear reduction ratio 265.2:1
  • Clutch Sliding Ring Gear
  • Drum size Drum size Diameter2.5"(63.5mm) Length 8.8"(224mm)
  • Cable 94ft of 21/64" diameter(28m of 9.2mm diameter)
  • Weight N.W.41k G.W. 45.5kg
Winche 4x4 12.000 Lbs
Valor Normal $435.000.-
Preventa $326.250.-
Specifications:
  • Single line rated pull 12000lb(5443kg)
  • Motor 6.0hp/4.5kw,Series Wound
  • Drum size Diameter 2.52?(64mm) Length 8.82?(224mm)
  • Cable 88ft of 3/8? diameter (27m of 9.5mm diameter)
  • NW/GW 42kg/46kg
Gatas Hilift 48" y 60"
48"
Valor Normal $65.000.-
Preventa $48.750.-
60"
Valor Normal $75.000.-
Preventa $56.250.-
Cintas de Tiro
9 metros x 6cm 8 toneladas
Valor Normal $27.000.-
Preventa $20.250.-
20 metros x 5 cm 5 Toneladas
Valor Normal $39.000.-
Preventa $29.250.-
Grilletes 4.5 Ton.
Valor normal $12.000.-
Preventa $9.000.-
La fecha de llegada de los productos es el dia 20 de Octubre Aprox.
A continuacion les detallo todas las formas de pago que existen para las compras realizadas en Merchat, para que puedan evaluar la que les sea mas conveniente para realizar sus pedidos.
Ademas de recordarles que contamos con servicio de atencion On-Line de 9:30 a 19:00 Horas.
Mails de contacto:
merchat_service@hotmail.com (Sebastian C.)
ventas@merchat.cl (Alvaro R.)
Efectivo:
  • 30% al momento de encargar y diferencia contra entrega, tambien se entiende por efectivo Cheque al dia.
Cheques*:
  • 1 Cheque a 30 dias, precio contado
  • 3 Cheques precio contado (compras hasta $300.000.-)
  • 5 Cheques con interes (Para compras sobre $300.000.-)
Tarjeta de Credito:
  • Hasta en 24 cuotas, con interes comercio (via transbank)
*Los cheques, se reciben previa verificación y Merchat Ltda., se reserva el derecho de recibirlos o no.
VALORES IVA INCLUIDO Y SE FACTURA
Atentamente
Staff. Merchat
Fono 2234337
www.merchat.cl
Antiguo 19-09-2010, 00:22:54   #2
pablo lizana
Contactar con pablo lizana a través de MSN Contactar a pablo lizana a través de Yahoo
Predeterminado Re: Preventa de winches, hi-lift y accesorios merchat 4x4
hola yo me anoto con la gata siempre y cuando no sea china que sea americana
pablo lizana está offline   Responder Con Cita
Antiguo 19-09-2010, 02:51:50   #3
x2 por aca ... hi lift original de 48 ...
hay soprtes para llevarla en la parrilla ARB ?
Antiguo 19-09-2010, 05:43:58   #4
Diablo
Empezado por pablo lizana Ver Mensaje
Empezado por JPVM Ver Mensaje
Hola:
Las gatas son importadas de USA, pero no son Hi-Lift Originales, las vimos en persona en miami y son de muy buena calidad, en cualquier caso si abonan y posteriormente no les convence, se puede cancelar el negocio sin ningun problema.
Antiguo 19-09-2010, 10:33:31   #5
pablo lizana
y de donde son las gatas pais de fabricacion
Antiguo 19-09-2010, 14:53:10   #6
Lino 4x4
Seguramente chinas. Si el cuento con los productos chinos, es que hay de distintas calidades. Creo que arman BMW o AUDI por esos lados
Antiguo 20-09-2010, 00:13:14   #7
Es muy cierto, cosas chinas hay buenas y malas, lo ideal es saber comprarlas y no caer con imitaciones malas , lo se en carne propia. Ahora el precio no es muy chino que digamos pues es no muy lejano a la original ... Ademas yo usaria tan re poco la Hi lift que se podria arriesgar.
Antiguo 21-09-2010, 16:22:17   #8
Kruger
Avatar de Kruger
Cuando llegan las ciantas de tiro?
Antiguo 21-09-2010, 16:23:58   #9
Kruger
Avatar de Kruger
Cuando llegan las cintas de tiro?
Antiguo 26-09-2010, 21:05:27   #10
johnfritz8
Me anoto con una cinta de tiro. Por favor envíame los datos para el depósito por PM.
Saludos!
johnfritz8 está offline   Responder Con Cita
La franja horaria es GMT -3. Ahora son las 13:45:03.
