Antiguo 06-01-2011, 08:52:37   #1
Carlos Cabrera
Predeterminado Compré de más...alguien lo quiere?
Hola Amigos.
Bueno , resulta que como soy un completo " Novato" en esto de los R/C ,y además me dejé llevar por los errados consejos de la vendedora de Tower H. ,compré este control de velocidad equivocado para mi Crawler.
Como no quiero hacer negocios para nada , lo ofrezco al mismo precio que me salió a mi , flete incluido y Tipo de cambio antiguo.
Sólo quiero recuperar la plata.
Es para velocidad con reversa y frenos ABS !
DTXM1059
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGZX1
Sumándole el Flete lo ofrezco a $24.000.-
Está completamemte nuevo y embalado.
Ojalá le sirva a alguien.
Carlos.
This is the DuraTrax IntelliSpeed Fwd/Rev AutosportSpeed Control for
stock motors from 18 turns up, and 4-7 cell batteries.
*** 120 Day Limited Warranty ***
FEATURES: Simple "Plug In" set up for a quick and easy speed control use
Digital glitch prevention
Fully proportional forward and reverse control, with ABS brake
Automatic set-up from the Tx. No adjustment dials or buttons, with
high-visibility Red and Green set-up LEDs
For stock motors having no fewer than 18 turns. Great for entry
level racing
Anti-lock Brake System (ABS) enables greater control while connering
Ultra high frequency gives smoother throttle response, cooler running
motors, and greater motor life
Built in ON/OFF switch lets the vehicle be turned ON at the flip of a
switch, not as soon as the battery is plugged in
Futaba J connector installed
INCLUDES: One Intellispeed Autosport Speed Control Unit with Gold Heatsinks
Pre-installed standard Tamiya type battery connectors
Pre-installed bullet style motor connectors
Pre-installed receiver connector,(FUTABA)
Mounting and hook up instructions
REQUIRES: Two .1uf capacitors (can use part number BRPC7110)
SPECS: Voltage input: 4 to 7 cells (4.8-8.4V) ON-resistance: FWD .007 Ohms
REV .014 Ohms
Maximum current: 128A Weight: 2.1oz (60g)
Size: 1.48"L x 1.34"W x .57"H
(37.5mm x 34mm x 14.4mm)
BEC Voltage/amps: 5V /1A
COMMENTS: Won't work with the 3PK in HRS mode. PCM and FM will work fine.
Última edición por Carlos Cabrera fecha: 06-01-2011 a las 09:41:09
Antiguo 06-01-2011, 09:24:11   #2
Matías del Río
Avatar de Matías del Río
Predeterminado Re: Compré de más...alguien lo quiere?
Interesante, soporta hasta 3 celdas y es con freno de gatillo... algo asi como el XL-5 pero con capacidad para 11.1v!!!!!!
Jarogoooooo!!!!!! instruyenos de este acelerador por fa!!!!
Antiguo 06-01-2011, 09:46:03   #3
Smile Re: Compré de más...alguien lo quiere?
Queeee !!! lei mal o dice
SPECS: Voltage input: 4 to 7 cells (4.8-8.4V) .. de cual es que ves cosas que no veo ???
Antiguo 06-01-2011, 09:50:22   #4
Matías del Río
claramente la electricidad y Yo no somos amigos.....
Antiguo 06-01-2011, 09:52:49   #5
jajajaj el tema es que no habla de lipo lo ya que no hay algun comentario de cutoff lo que entiendo sirve para Nihm .. ahora como opcion para repuesto o sacrificarlo para el agua .. encuentro que esta bien.
Suerte en la venta Carlos.
Antiguo 06-01-2011, 09:55:01   #6
jarogo
Edad: 77
Hola Matias
El esc es fundamentalmente para nmetal o ncadmio de 4 a 7 celdas, Si bien es cierto se podía conectar lipo, esta debe ser de 2 celdas máximo y no tiene corte de bajo voltaje.
Teniendo presente las restricciones que te acabo de mencionar te puede servir.
Se ajusta automático al prender la radio.
Eso
Última edición por jarogo fecha: 06-01-2011 a las 10:39:49
Antiguo 06-01-2011, 09:56:24   #7
Carlos Cabrera
Aunque hablaste en chino... , gracias P.D. !
C.
Antiguo 06-01-2011, 10:02:15   #8
jarogo
Edad: 77
Yo tengo uno igual , pero para motores de 8 vueltas hacia arriba. Lo impermeabilicé . Lo he metido al agua con tutti y hasta ahora cero problemas.
Es más que el que viene en la WK y tamiya del rtr
Antiguo 06-01-2011, 11:01:38   #9
C.
jajaja es un buen ESC .. yo lo compraria pero la verdad es que me he llenado de cosas que tengo que hacer un recuento, en una de esas la semana que viene hago un inventario y si aun esta me lo llevo ..
p.d. en una de esas podemos hacer algun trueque donde los 2 nos beneficiamos .. hablemos por PM.
Antiguo 06-01-2011, 12:35:26   #10
Carlos Cabrera
Thumbs up Re: Compré de más...alguien lo quiere?
Última edición por Carlos Cabrera fecha: 13-01-2011 a las 15:36:20
La franja horaria es GMT -3. Ahora son las 08:43:09.
