Antiguo 06-01-2011, 11:41:11   #1
renatobuster
Avatar de renatobuster
Edad: 28
Wink axial scx10
bueno talvez para febrero me compre una axial scx10 en hobby express
yo creo que una dingo me voy a comprar pero me gustaria saber con que viene
sus caracteristicas si tiene bloqueo todo que motor tiene etc...
renatobuster está offline   Responder Con Cita
Antiguo 06-01-2011, 12:00:22   #2
Smile Re: axial scx10
Empezado por renatobuster Ver Mensaje
Pues si talvez te la compras hay bastante info en la web donde puedes ver las caracteristicas ..
Aqui te dejo una lista de las cosas que trae ...
SCX10 TR Features:
Complete ready to run out of the box
4WD
27T Electric Motor: Tear up the terrain in-door or out-doors. Easy Operation: No Tuning, No Fuel, No Loud Exhaust Noise. Just Plug'n'go!
20T pinion paired with an 87T spur gear gives you quick acceleration while still allowing for a smooth low end speed range
True Beadlocks: No Messy Glue!
Hi-quality Composite Plastic and Metals
6 LED's: 4 white LED’s for the front and 2 red LED’s for the rear
Electronic Speed Controller (ESC): forward and reverse speed controller.
Hi-Torque metal gear servo helps hold your line when rock crawling
Solid Rear Axle lockouts improve ground clearance and offer a more realistic appearance
Slipper Clutch: Reduces gear wobble for a more efficient drivetrain.
Allows a motor to work more efficiently and greatly enhances the durability of the drivetrain.
Steel chassis rails with a molded composite plastic cross members provide a solid and rigid chassis
Ultra compact and lightweight transmission
Full Ball bearings
Overall gear ratio range from 15:1 to 74:1
Transmission: 2.6:1; center mounted
Tyres: Pro-Line 1.9 Flatirons tires Wheels: Axial 1.9 8 Hole Beadlocks (Satin Chrome)
Suspension: 3 Link
Drive Shafts: Universal front and rear
Spec Check:
Chassis Dimensions a. Wheelbase: 290mm (11.4”)
b. Width: 227mm (9”)
c. Height: 150mm (5.9”)
d. Weight: 2086g (4.6 lbs)
Ground Clearance: 68mm (2.7”)
Body Dimensions
a. Length: 425mm (16.7”)
b. Width without fender flares: 180mm (7.0”)
c. Width with fender flares: 226mm (8.9”)
d. Height: 145mm (5.7”)
Antiguo 06-01-2011, 12:13:38   #3
renatobuster
Edad: 28
Wink Re: axial scx10
gracias y tambien me gustaria saber si tiene bloqueo
Antiguo 06-01-2011, 12:20:31   #4
Creo que los modelos SCX-10 traen spool .. bloqueados al 100%.
Antiguo 06-01-2011, 12:47:36   #5
renatobuster
Edad: 28
Predeterminado Re: axial scx10
gracias a finales de enero vendo mi clod y mas unos ahorros me la compro
Antiguo 06-01-2011, 13:01:13   #6
renatobuster
Edad: 28
pregunta para los que han comprado en hobby express, cuanto se ha demorado en llegar algo que compren en la pagina
gracias!!
Antiguo 06-01-2011, 14:06:24   #7
gracias!!
Creo que entrega en 2 semanas.
Antiguo 07-01-2011, 23:17:36   #8
Alexbike
Avatar de Alexbike
15 dias exactos.
cero problemas con ellos, cumplieron como dijeron..
dueño de una SCX10 Honcho comprado en hobby..
Alexbike está offline   Responder Con Cita
Antiguo 08-01-2011, 12:45:27   #9
renatobuster
Edad: 28
Question Re: axial scx10
y que tal es la honcho de fabrica
con que viene de hobbyexpress
si viene armado etc...
Antiguo 08-01-2011, 17:35:08   #10
Alexbike
Avatar de Alexbike
hola ..
viene listo, llegar y andar ...
ahora debes incluir baterías y cargador en la compra.
yo compre una scx10 honcho, increíble funcionamiento, ninguna falla grave, solo que se soltaban los cardanes pero con algo de traba pernos y listo, y un dia que dejo de funcionar, lo revise y tenia un cable en el motor cortado. soldadura y otra vez funcionando..
a hobby le encargue 2 baterías intellec de 5000 mAh. que me duran 2,5 horas cada una y un cargador piranha, modelo digital peak charger. la verdad todo funcionando de pelos.. este axial ademas trae repuestos varios.. que son de plásticos si, pero duran mucho.
La franja horaria es GMT -3. Ahora son las 08:29:04.
