Antiguo 01-06-2011, 14:08:13   #1
GEOEXPLORER
Predeterminado Como reconocer un Motor 350
Hola;
Tengo un motor que me llegó de regalo y me dijo el anterior dueño que es un Chevrolet 350 que estaba en una camioneta Cheyenne, más detalles no tengo.
Como puedo identificar con más precisión si es Gen I, II o III... y si es realmente un 350. En que debo fijarme para poder saber bien que es lo que tengo.
Gracias.
GEOEXPLORER está offline   Responder Con Cita
Antiguo 01-06-2011, 18:14:22   #2
Cristian Moraga
Predeterminado Re: Como reconocer un Motor 350
Empezado por GEOEXPLORER Ver Mensaje
Hola;
Gracias.
busca el block casting number
y buscalo en esta pagina http://www.mortec.com/castnum.htm
Antiguo 01-06-2011, 18:19:21   #3
Kruger
Avatar de Kruger
Hola;
Gracias.
Si es Cheyenne debiera ser un 350 TBi I Gen, Probablemente un L05
L05
The L05 was introduced in 1987 for use in Chevrolet/GMC trucks in both the GMT400 (introduced in April 1987 as 1988 models) and the R/V series trucks such as the K5 Blazer, Suburban, and rounded-era pickups formerly classed as the C/K until 1991 which includes chassis cabs and 4-door crew cabs. Although usage was for trucks, vans, and 9C1-optioned Caprices, the L05 was also used with the following vehicles:
1992/1993 Buick Roadmaster sedan and station wagon
1990–1992 Cadillac Brougham (optional engine)
1993 Cadillac Fleetwood
1992/1993 Chevrolet Caprice Wagon (optional engine)
1993 Chevrolet Caprice LTZ
1992 Oldsmobile Custom Cruiser Wagon (optional engine)
L05 usage was replaced by the GM LT1 after 1993 in GM B-Bodies until production ceased in 1996.
In mid 1996 the L05 was equipped with Vortec heads used in the 1996 G30.
L31
The L31 replaced the L05 in 1996 – known as the Vortec 5700. The Vortec 5700 produces 255 hp (191 kW) to 350 hp (261 kW) at 4600 rpm and 330 ft-lbf (448 N·m) to 350 ft-lbf (475 N·m) of torque at 2800 rpm. Known as the GEN 1+, this was the final incarnation of the 1955-vintage small block, ending production in 2005 with the last vehicle being a Kodiak/Topkick HD truck. Volvo Penta and Mercury Marine still produces the L31. The "MARINE" intake is a potential upgrade for L31 trucks. Using this "MARINE" intake will allow the use of common types of injectors with various flow rates while still maintaining emission compliance.
La franja horaria es GMT -3. Ahora son las 04:06:22.
