Antiguo 17-07-2011, 16:35:06   #1
GUIPARTS4X4
Contactar con GUIPARTS4X4 a través de MSN
Predeterminado LED Light bars, lo ultimo en iluminación OFFROAD
Comparación en aplicación OFFROAD:
Focos desde 2" hasta 50", barras singles y dobles.
Placas protectoras (ambar, blue, pink, red, clear)
Soportes y clamps todos los tamaños, para instalar en parachoques, tubos, barras antivuelco.
Aplicaciones para 4x4, ATV, industria, agricultura, mineria, marina, etc.
Aca van algunos precios:
Foco 2x2
$110.000.- c/u
$198.000.- el par
Specs del fabricante:
A 4 LED light in a compact 2x2 package that can be used for anything from a reverse light on a truck, a handlebar light on a Motorcycle, to a flood light on a trailer. With over 1300 lumens of light in each one, this small light has the same light output as a 50W MR16. At a small 3"-3" this light can fit anywhere. Pulling only 15W you won't find a more efficient, compact light source in HID or halogen.
4" SERIES "E" BARRA LED
$220.000.- c/u
4" "E" Series LED Light Bar The new "E" Series High Intensity L.E.D. General Specs: 93% Optical Efficiency Shockproof No Vibration 50,000+ Hour Life Span Easy Two Wire Installation .1.16 Amps 15.6 watts 1440 Lumens Patented Hybrid Technology runs lights at 90% efficiency which is unmatched in the industry. Dimensions: 3 1/4" High 3 3/4" Deep 5 3/8" Long
6" SERIES "E" BARRA LED
$286.000.- c/u
6" "E" Series LED Light Bar The new "E" Series High Intensity L.E.D. General Specs: 93% Optical Efficiency Shockproof No Vibration 12 LED's with 50,000+ Hour Life Span Easy Two Wire Installation 1.73 Amps 23.4 watts 2160 Lumens Patented Hybrid Technology runs lights at 90% efficiency which is unmatched in the industry. Dimensions: 3.375" High 3.625" Deep 7 3/8" Long
10" SERIES "E" BARRA LED
$385.000.- c/u
General Specs: 93% Optical Efficiency Shockproof No Vibration 20 LED's with 50,000+ Hour Life Span Easy Two Wire Installation 2.89 Amps 39 watts 3600 Lumens Patented Hybrid Technology runs lights at 90% efficiency which is unmatched in the industry. Dimensions: 3.375" High 3.625" Deep 11 3/8" Long
MONTURA PARA PAR DE 4" LED - PARRILLA
$45.000.- c/u
Why LED? A light-emitting-diode (LED) is a semiconductor diode that emits light when an electrical current is applied in the forward direction of the device, as in the simple LED circut. The effect is a form of electroluminescence where incoherent and narow-spectrum light is emitted from the P-N junction in a solid state material. Advantages of LED lighting: 50,000 hour life expectancy Very High Lumens per Watt No glass lens to break No Bulbs to Burn out No Ballast to Mount Rigid Industries Advantage,it's all in the reflector. Patented Super Efficient Reflector 93% efficient vs. 72% "Brand X" reflectors Available in both Pencil and Flood Beam More Light with Less Power, Heat and size. Much Father Projection Multi Source Light No "bouncing" beams Virtually eliminates HID vibration If one LED fails the other LEDs will not Greatly Reduces eye fatigue.
Escribanos o llamenos para cotizar nuestros prodcutos:
Última edición por GUIPARTS4X4 fecha: 19-07-2011 a las 01:22:43
GUIPARTS4X4 está offline   Responder Con Cita
Antiguo 17-07-2011, 22:47:46   #2
baiker
Predeterminado Re: LED Light bars, lo ultimo en iluminación OFFROAD
es posible que me pongas los valores, me interesa un par para mi 4x4 en lo posible los mas cuadraditos y una foto para ver el tamaño real
Antiguo 17-07-2011, 22:50:26   #3
Alberto Bravo
Avatar de Alberto Bravo
X 2
Antiguo 18-07-2011, 20:10:26   #4
Manuel Fuentes
Avatar de Manuel Fuentes
Falto publicar los precios.
Manuel Fuentes está offline   Responder Con Cita
Antiguo 19-07-2011, 00:43:15   #5
GUIPARTS4X4
Estimados,
Aca van algunos precios con fotos y specs:
Foco 2x2
$110.000.- c/u
$198.000.- el par
$220.000.- c/u
$286.000.- c/u
$385.000.- c/u
$45.000.- c/u
Antiguo 19-07-2011, 01:24:50   #6
GUIPARTS4X4
En el primer post agregamos algunos precios con foto y specs del fabricante, con detalle tecnico del alcance de cada una.
Antiguo 19-07-2011, 11:00:10   #7
Zorro
No habia visto este thread, EXCELENTE Gui!!!
Esos focos son SONICOS, el año pasado en el baja gringo no los cachaba y me costo un poco descubrir que era, estaban instalados en casi todos los autos que corrian, y en la noche iluminaban muy bien.
En el Dakar tambien lo usaban varios vehiculos, sobre todo los camiones, que traian instalados varios y por todos lados.
Suerte en la venta y el que compre no va a quedar insatisfecho con la compra.
Saludos!
Antiguo 19-07-2011, 18:13:25   #8
GUIPARTS4X4
Saludos!
Muchas gracias Francisco, la mejor recomendación la puede hacer alguien que los ha visto en acción en terreno y ha comparado la diferencia.
Antiguo 19-07-2011, 19:33:58   #9
mariof
Empezado por GUIPARTS4X4 Ver Mensaje
filete Guillermo, yo vi un jk con un skybar de 50 y son atomicos wn.
cuando veamos los covers me cotizas una
Mario
mariof está offline   Responder Con Cita
Antiguo 20-07-2011, 10:55:16   #10
GUIPARTS4X4
Empezado por mariof Ver Mensaje
Mario
Niun problema Mario cuando quieras.
La franja horaria es GMT -3. Ahora son las 04:15:24.
