Antiguo 03-11-2011, 11:46:57   #1
caxtrol
Predeterminado Vendo Apexi Super AFC II
Por no uso, vendo Apexi Super AFC II con muy poco uso, "Black Edition", harto mas piola que la plateada.
Ideal Turbos, Supercargadores y motores potenciados.
Con ramal y soporte
$180.000.-
Caxtrol
How does the AFC Air Flow Converter Work?
The A'PEXi Air Flow Converters work by intercepting the signal between the car's air flow meter and the ECU. The Air Flow Meter is the device that tells the ECU how much air is entering the engine so that the ECU can add the correct amount of fuel.
The ECU calculates the proper ratio of fuel to air for a stock, unmodified engine. Certain engine modifications can cause the dynamics of the engine to require more fuel. In this case, there are two common options for modifying the amout of fuel being input into the engine. One can either install larger injectors or increase the fuel pressure to the stock injectors is increased.
Since the stock ECU thinks that it knows how much fuel it is putting into the engine based on the stock injector size and the stock fuel pressure, changing either of these will result in increased fuel. You may get lucky and just pick the perfect injector or fuel pressure that gives you the perfect air/fuel ratio. You may also get lucky and pick this weekends winning lottery numbers. In either case I wouldn't bet the farm on it. The Air Flow Converter gives you the means to adjust the amount of fuel that the ECU injects into the engine by modifying the signal from the air flow meter. This is done a specific RPM levels. This way you can tell the engine that a certain amount more air is flowing into the engine as a specific RPM than is really entering the engine, and the ECU will add that much more fuel. Decrease it at another RPM level and the ECU will decrease the fuel into the engine.
caxtrol está offline   Responder Con Cita
Antiguo 04-11-2011, 09:04:02   #2
caxtrol
Predeterminado Re: Vendo Apexi Super AFC II
Sigue a la venta para quienes quieran controlar los inyectores .......
Caxtrol
Empezado por caxtrol Ver Mensaje
Con ramal y soporte
$180.000.-
Caxtrol
Antiguo 04-11-2011, 12:17:20   #3
samurai xxx
Avatar de samurai xxx
ola te ofrezco 130.000 lks altoke.
saludos miguel tapia 86693630
samurai xxx está offline   Responder Con Cita
Antiguo 04-11-2011, 14:26:04   #4
caxtrol
Miguel, colocale 30.000 mas arriba y es tuya. No tengo apuro como para liquidarla en lo que me ofreces.
Saludos y quedo a la espera de tus comentarios
Jcv
Empezado por samurai xxx Ver Mensaje
Antiguo 07-11-2011, 08:28:01   #5
caxtrol
Sigue en venta
Caxtrol
Jcv
La franja horaria es GMT -3. Ahora son las 16:57:45.
