Antiguo 01-03-2013, 23:50:14   #1
PiscolaSureña
Predeterminado Old Man Emu Delanteros para Toyota Hilux
Vendo Paquetes Delanteros Old Man Emu para Toyota Hilux... Puro filete!!!
Para los que se quejan que las Hilux son duras y que rompen paquetes delanteros, AQUI esta la solucion!!!
$170.000 el par / Estan nuevos
Juan Pablo Garcia
j.pablog@gmail.com
82190257
Descripcion:
Old Man Emu 4X4 Suspension
Emu Dakar Leaf Springs
Part of ARB's integrated 4x4 suspension systems, Emu Dakar leaf springs are engineered to provide optimum ride performance irrespective of the operating conditions the vehicle's suspension is required to work under.
Numerous spring options are available to suit a multitude of applications, allowing you to set your vehicle up for recreational or commercial purposes. Feature packed, a set of Emu Dakar leaf springs matched to a set of Old Man Emu 4x4 shock absorbers will deliver vastly improved ride, handling and load carrying capability.
  • Draw tapered and diamond cut leaves: Ensure the load is progressively distributed over a larger surface area, reducing the high stresses that develop at leaf ends. This provides increased ride quality and protection against leaf breakage, significantly increasing the spring life.
  • Bolt clamps and liners: The leaf clamps are bolted to allow installation of anti squeak nylon liners.
  • Fully scragged and load tested: Scragging ensures the spring takes a permanent ‘set’ which reduces the risk of sagging. Load testing ensures the spring meets the required specification.
  • Graphite coating: To further reduce the friction between the spring leaves and friction pads.
  • Military wrap: Designed to provide added safety.
  • Anti friction pads: Regreasable nylon interleaf liners reduce friction at the leaf tips where the load is the greatest.
  • Flat axle seat area: Allows a positive, safe axle mount reducing spring stress and increasing spring life.
  • Shot peening: The tension side of all leaves is shot peened to reduce spring stress. This process can double the life of a spring.
  • Two-stage leaf pack: Featured on most rear springs for optimum comfort. When unladen the vehicle is largely riding on the primary stage, with the secondary stage providing additional support when a heavy load is added.
PiscolaSureña está offline   Responder Con Cita
Antiguo 04-03-2013, 22:37:49   #2
PiscolaSureña
Predeterminado Re: Old Man Emu Delanteros para Toyota Hilux
Fotos de los paquetes...
Antiguo 04-03-2013, 22:51:38   #3
andres785
Realmente son suaves, los recomiendo más que los TG
Antiguo 05-03-2013, 13:56:52   #4
PiscolaSureña
Vendidos a Jorge Heuser
Se fueron a Pto. Montt
Gracias TA
La franja horaria es GMT -3. Ahora son las 18:02:30.
