| Venden - Vehiculos 4X4 Espacio para avisos de venta (de caracter no comercial) de Vehiculos 4x4. Todo mensaje que no tenga que ver con el tema será eliminado sin previo aviso. |
#11 |
jajaja Si ya había una, había que tener la parejita
#12 |
Uta el wn Caliente
TE PASASTE !!!!!!
traktorke Wrangler Jk Wrangler JL Can-am Maverick x3 Rallye Can-am maverick x3 xrs2020 www.kdms.cl www.facebook.com/kdmsmotorsports www.instagram.com/kdmsmotorsports |
#13 |
#14 |
#15 |
#16 |
Comanche Vendida, gracias Richard!
saludos! |
#17 |
mitad y mitad
http://en.wikipedia.org/wiki/Jeep_Comanche Design[edit] American Motors' Jeep designers based the Comanche MJ body, styling, engineering, and drivetrain on the Cherokee XJ, which had been introduced for the 1984 model year.[3] The Comanche had a more conventional removable cargo box and conventional body-frame design. The Rabbit Pickup (Caddy)] and Rampage are technically coupe utilities, not trucks, since the cargo bed is an integral part of the body structure and not removable.[citation needed] AMC's Jeep engineering staff designed a rail "frame" structure to support the cargo box that was unitized with the front passenger section of a four door XJ Cherokee. Two cargo bed lengths were used; one for the seven-foot long-bed model, which appeared first in 1985, and a second, shorter version for the six-foot cargo bed, which debuted for the 1987 model year. The "frame" structure (called a "Uniframe" by Jeep) was made up like unitized car body main supports - from stamped sheet metal components spot welded together. For strength, the rails were over eight inches deep (top to bottom), much deeper than conventional mid size truck frames (1983 Jeep J-10 fulls size truck frame is 6.75 inches at the deepest point). This structure was pioneered by AMC for the 1971 "Cowboy" compact pickup prototype. From 1985 to 1987, the Jeep Comanche grille had ten slots in a similar configuration to the 1984-1987 Cherokee XJ, while from 1988 to 1992, this configuration changed to eight slots to match with the SUV.[9] A new "4x4" badge, similar to those found on the Cherokee and Wagoneer models, was affixed to the upper rear of the cargo box on all the four-wheel drive models.[1] After the Chrysler buyout of American Motors for $1.5 billion on March 9, 1987, designed to capture "the highly profitable Jeep vehicles ... and 1,400 additional dealers"[10] the Jeep Comanche, like the similar Cherokee, received only minor changes. These were primarily to improve reliability and parts interchangeability with other Chrysler-built vehicles. Última edición por Kruger fecha: 24-04-2014 a las 14:11:19 |
#18 |
Que pasó Carlitos ? jajaj
Así es, como dice Max mitad/mitad Técnicamente se llama Uni-Frame, mezcla chassis en el pick up y unibody en la cabina... Esto entrega un bajo peso y mayor resistencia que un monocasco completo. Estas pick up corto tienen un muy buen WB de 107" en una carrocería de tamaño compacto, convirtiéndolas en una excelente base para un proyecto entretenido. Saludos! |
#19 | |
#20 |
cuando hay, uno no tiene; cuando uno, tiene no hay...
