Antiguo 24-02-2004, 23:17:09   #1
Predeterminado Anchos de Ejes (o yugos)
Para los que estan pensando en hacer un cambio a eje rigido o por cultura general, estos son los anchos de los ejes mas populares :
(F) = Front , eje delantero
(R) = Rear, eje trasero
Toyota
Mini (Hilux) 79-85 (F) 8" 55" (pass side drop)
Mini (Hilux) 79-85 (R) 8" 55"
Mini (Hilux) 86+ (R) 8" 58"
4Runners 96+ (R) 8" 60"
Tundra/T100 (R) 8.4" 66"
FJ40.45.55 (F) 57" (pass side drop)
FJ40.45.55 (R) 55"
FJ60.62 (F) 60" (pass side drop)
FJ60.62 (R) 58"
FJ80 (F) 64" (pass side drop)
FJ80 (R) 63.5"
Ford
Bronco 77 (F) Dana 44 58"
Bronco 77 (R) Ford 9" 57"
F250 78-79 (F) Dana 60 69.25" (driver side drop, king pin, leaf spring span: 31.5")
F350 78-79 (F) Dana 60 69.25" (driver side drop, king pin, leaf spring span: 31.5")
F350 '85-'91.5 (F) Dana 60 69.25" (driver side drop, king pin, leaf spring span: 36.5")
F350 '92-'99 (F) Dana 60 69.25" (driver side drop, balljoint, spring span: 36.5")
1/2 Ton '70 (F) Dana 44 65" (high pinion)
1/2 Ton '70 (R) Dana 60 65"
Chevy
K30 '79-'87 (F) Dana 60 69.5" (pass. side drop, king pin, leaf spring span: 32")
K30 CC '88-'91 (F) Dana 60 69.5" (pass. side drop, king pin, leaf spring span: 32")
Jeep
Cherokee Chief 81 (F) Dana 44 61"
Grand Wagoneer 89 (F) Dana 44 61.5"
Wagoneer 81 (F) Dana 44 60.5"
CJ-6 74 (F) Dana 30 51.5"
CJ-6 74 (R) Dana 44 50"
CJ-7 83 (F) Dana 30 56"
CJ-7 83 (R) AMC 20 55"
TJ Rubicon 03 (F) Dana 44 61"
TJ Rubicon 03 (R) Dana 44 60"
International
Scout 80 (R) Dana 44 60"
Mercedes
Unimog (F) 404 69" (driver's side drop)
Unimog (R) 404 69" (centered)
Unimog (F) U-1300 82"
Unimog (R) U-1300 82"
Unimog (F) 411 55.5"
Unimog (R) 411 55.5"
Nissan
Hardbody (D21) 86.5-97 (R) H233B 59"
Hardbody (D21) 86.5-90 (R) C200 59"
Frontier (D22) 99-2000 (R) H233B 62.5"
Isuzu
Trooper II 87 (R) Corporate 59"
Rodeo pre-'97 (R) Dana 44 58" (sua)
Rodeo 97-99 (R) Dana 44 60.5" (4-link)
Rodeo 00-03 (R) Dana 44 63" (4-link)
KIA
2000 Sportage (R) 60"
Antiguo 24-02-2004, 23:36:18   #2
Horacio
Muuuu wena la info, te felicito!!!!
Antiguo 25-02-2004, 08:54:25   #3
m.J.n.
Hola Jp , tu q eres el q conoce de nissan
q sabes hacerca de los yugos de patrol y los del
safari largos , relaciones,etc
Mario
m.J.n. está offline   Responder Con Cita
Antiguo 25-02-2004, 10:46:12   #4
Empezado por MJN
Mario
Hola compadre, hasta lo que se, los Patrol (o Safari = nombre usado en Japon para el mismo) (c/ motor P40 del 80 - 85 que habian aca) no los cacho mucho, pero sé que muchos usan los ejes traseros H233B (y delantero tambien a veces) con relaciones 4.11 , este es el mismo que mi D21 del 93 trae atrás. En todo caso en el sitio www.4x4parts.com hay R&P de 4.875 para arriba para el eje H233B.-
Antiguo 25-02-2004, 13:57:45   #5
Jorge Heuser
:D de ahi les cuento
Antiguo 25-02-2004, 14:20:57   #6
Empezado por Jorge Heuser
Ah, no, no es tan facil la cosa, si la tirastes, cuenta cuenta
Antiguo 25-02-2004, 14:26:01   #7
Empezado por Gonzalo Bravo
Hace como 1 año que estamos tratando de sacarle info y fotos de la Subaru MV (BRAT) V8 y nada .... de un par de eje portales 'Mog va a ser mas dificil ...
Antiguo 25-02-2004, 18:50:36   #8
m.J.n.
grax JP :wink:
seguir buscando mas info
pero con lo q me dijiste ya puedo buscar
de forma mas clara
grax de nuevo y salu2
Antiguo 13-03-2004, 14:12:16   #9
Jorge Heuser
Empezado por JPVM
Ya para que no llores JP y no te coma la curiosidad Gonzalo les muestro un pequeño adelanto
Es que justo por esos dias,(cuando escribio el post de los ejes JP)recien habia negociado unos ejes de un mog 404 que estaban abandonados en el campo de un amigo(por eso la carita :D )y como no tenia camara dig.no les pude tirar unas fotitos(hasta que me hicieron comprar un los wones :? :wink: )
Bueno esto es un adelanto de un proyecto que tengo en mente hace como 3 años :? (osea va a salir el año del p.co )
Los diferenciales
Los neumaticos barro y verano
Y por ultimo una foto del motor big block 390 (esperando ser envenenado mas un super charger Esta ultima probando previamente a ver si es necesario( loco e mier..))
[/img]
Antiguo 13-03-2004, 14:31:01   #10
MLOZANO
Got Jeep?
Avatar de MLOZANO
Empezado por JPVM
Es que justo por esos dias,(cuando escribio el post de los ejes JP)recien habia negociado unos ejes de un mog 404 que estaban abandonados en el campo de un amigo(por eso la carita :D )y como no tenia camara dig.no les pude tirar unas fotitos(hasta que me hicieron comprar un los (%&#@) :? :wink: )
Los diferenciales
[/img]
Hartas piezas!!!... para cual proyecto corresponde cada una?
Que medida son esos neumaticos de "Verano"?
Mariano
UTV Polaris Ranger RZR 2008
ejes anchos en samurai... 2 mangas largas..y centrado...........sera factible? sj413team General 4WD 0 13-04-2007 10:56:48
yugos de sj410 con ejes y coronas Jorge H. Dìaz B. Venden - Partes y accesorios para 4X4 0 23-02-2007 12:54:50
Busco Yugos Anchos para Samurai GatoMontes Compran 11 02-01-2006 11:43:32
habia visto ejes anchos, peroooo.... DTR General 19 30-10-2005 01:21:19
información sobre ejes (Yugos) cebra4x4 General 4WD 3 23-04-2005 10:49:03
La franja horaria es GMT -3. Ahora son las 08:22:28.
