Antiguo 17-06-2010, 20:03:03   #11
Francisco sj-413
Avatar de Francisco sj-413
Predeterminado Re: Toyota Land Cruiser fj-70
Empezado por Majitu Lindu Ver Mensaje
jajajaj calentin , apuesto que si tuvieras las monedas y solo tuvieras el tlc ya seria tuyo , jejejejejejeje. ta filete
demas jajajajajaja
Antiguo 17-06-2010, 20:50:19   #12
Gerardo
Avatar de Gerardo
Contactar con Gerardo a través de MSN
uta si tuviera la plata............. !!!!!!!!!!!!!!!!!!
Gerardo está offline   Responder Con Cita
Antiguo 17-06-2010, 23:09:25   #13
Chungungo
San Wikipedia....
The 3F-E was designed in 1985 and, in 1988, became the powerhouse for the FJ62 Land Cruiser. It is very similar to the 2F engine except that it is equipped with EFI (electronic fuel injection, carbureted in other countries), a vastly improved emissions system and a smaller displacement. The smaller displacement in the 3F-E was caused by shortening the piston stroke; this also caused the displacement to shrink from 4.2 liters to 4. However, even with this reduction, the engine power increased by 15 kW (20 hp) and 14 N·m (10 ft·lbf) of torque. As a result of these changes to the engine the redline was increased, allowing a wider powerband which made this engine far more suitable for on-road use.
In 1992, the F series engines, after almost 45 years, finally ceased production. In 1993, the F series was replaced by the dual overhead cam (DOHC) 1FZ-FE engine.
Due to the slow-revving design of these engines, it is not uncommon to see them reach over 300,000 miles (482,800 km) before needing a major overhaul.
Retrieved from "http://en.wikipedia.org/wiki/Toyota_F_engine"
Antiguo 17-06-2010, 23:39:31   #14
Tractor
Oiga VECINO jejejejeje le interesa hacer un cambalache?????????
Tengo un Samurai catalitico 95, con algo de equipamiento, te podria interesar.
Atento a tus comentarios.
Tractor está offline   Responder Con Cita
Antiguo 18-06-2010, 10:22:48   #15
CristianRamirez
creeme q si jajajjajajajaj
Antiguo 08-07-2010, 18:03:47   #16
Francisco sj-413
UP!!!!!
Antiguo 08-07-2010, 20:13:21   #17
sskare
Pancho:
Habria que agregar que tiene:
Jaula
Candados 2"
Multiple escape
Bovina Alta
sskare está offline   Responder Con Cita
Antiguo 19-07-2010, 13:33:22   #18
Francisco sj-413
!!!!!! Up!!!!!
Antiguo 26-07-2010, 14:38:49   #19
Francisco sj-413
!!!!Vendido!!!!
Antiguo 26-07-2010, 15:12:20   #20
Roland
Avatar de Roland
Empezado por Francisco sj-413 Ver Mensaje
!!!!Vendido!!!!
Y quien se llevó tremenda máquina a la casa?????
La franja horaria es GMT -3. Ahora son las 11:22:25.
