Antiguo 13-10-2005, 22:35:04   #11
juaco fernandez
Avatar de juaco fernandez
Que encontraste ???
juaco fernandez está offline   Responder Con Cita
Antiguo 13-10-2005, 22:45:13   #12
Empezado por juaco fernandez
Que encontraste ???
Los rates, pero no se que pasa que se me queda pegado el PC cuando los pego, debe ser un Virus de Chrysler
Antiguo 13-10-2005, 23:13:14   #13
Que encontraste ???
Te los Mande por PM, no hubo caso de ponerlos.-
OEM Old man EMU XJ is supposedly 142-147 lb/in rate. 17" length 5.25" diameter
OEM ZJ with 4.0 is supposedly 190 lb/in rate front and rear.
OME 930 coils: 160 lb. spring rate. 1.75" of lift on XJ
OME 934 coils: 180 lb. spring rate.The 934 spring is 35 mm (1.37") longer than the 930 spring.
Tera 4" TJ coils have a 200 lb/in rate , 20.25" tall unloaded
Tera 3" TJ coils have a 170 lb/in rate
RE Rubicon Express 4.5in ZJ coils are 240 lb/in. give 5.5" ish of lift on an XJ 22" tall unloaded
RE 5.5XJ coils are 4.5ZJ coils.
Rusty's 6.5" 22" long, 12 wraps of 5/16" stock
Última edición por Gonzalo Bravo fecha: 13-10-2005 a las 23:26:35
Antiguo 13-10-2005, 23:30:41   #14
Rusty's 4.5" coils give 5" of lift and have a 150 lb/in rate, 22" tall unloaded
Rustys 3" coils give 3" and have 150 lb/in rate.
Rancho 3" coils, at least the old coils give about 2 1/4" of lift on an XJ and have a very high 235 lb/in rate.
Rockkrawler 6.5" are 165 lbs/in
SJ Sky Jacker 3" ZJ coils 218 lbs/in
SJ 6in XJ RR coil is 13 coils and same height and thickness as the RE ZJ4.5in XJ5.5in coil.
Antiguo 13-10-2005, 23:30:59   #15
The aerostar spring are realy soft. In fact, I would think that the aerostar spring would be to soft for a 4.3 setup..(Samurai)
Aerostar Passenger are in the 100 range
Aerostar van (no rear windows) 110-120
TJ Procomp 4" 150-155
Tracker front 375 (IFS)
Tracker rear 110-120
Antiguo 14-10-2005, 11:27:17   #16
Fernando Vliegenthart
Contactar con Fernando Vliegenthart a través de MSN
Empezado por FOURWHEELROD
me colgare de tu post.... debo poner unos espirales mas largos a mi Hilux, ya que despues de un año de uso han cedido una pulgada y media. Esto hace que el conjunto no tenga el equilibrio que corresponde. Ademas no aprovecho bien el recorrido en absorcion.
Donde consigo espirales mas largo?
Aprovecho de preguntarle a Fernando...... porque sacar la barra panhard?, yo si elimino la mia, se desarma todo a penas me muevo.... no sera la barra estabilizadora la que sacas?
Rod
estimado, tiene toda la razon, es la estabilizadora la que no instale, si tengo panhard, sorry for the mistake..............
Fernando Vliegenthart está offline   Responder Con Cita
Antiguo 14-10-2005, 12:01:12   #17
HAKUNA
Empezado por Fernando Vliegenthart
juaco, yo me traje un juego de espirales delanteros para XJ, era el kit de skyjacker para subir el cherokee en 5.5 pulgadas.
el diametro del alambre es de 0.61 pulg. el diametro externo del espiral es de 5.25 pulg. el diametro del espiral desde el centro del alambre es de 4.63 pulgadas.
a mi me los vendieron como de 200 lb/pulg, al meter todos los datos arriba mencionados la formula arroja un spring rate de 235, pero puede ser que yo conte las vueltas efectivas antes de instalarlo, ahora instalado debo hacer los calculos de nuevo.
el resultado final es espectacular, el rocky quedo mejor que con las bandejas originales y sin panhard en curvas (rapido) no se mueve mucho (amortiguador rancho en 3)
te dejo una foto de los espirales
quizas te refieres a sin barra estabilizadora, por que con yugo delantero imposible andar sin panhard, a no ser que tengas 4 link triangulado.. :???:
hakuna
Antiguo 14-10-2005, 12:21:00   #18
Empezado por HAKUNA
hakuna
amigo hakuna, gracias por la observacion, ya corregi la info un mensaje mas arriba
Dudas sobre Levante Samurai II 98 David Yakich General 4WD 0 25-02-2007 22:12:18
Algunas Dudas Sobre Las Proximas Modificaciones Sr.sj410 General 4WD 22 23-02-2006 12:59:45
consulta sobre espirales aerostar KARLITROZ POZO General 4WD 21 27-05-2005 18:23:05
Hola, Alguien tiene informacion sobre hilux con espirales chevota General 4WD 25 02-12-2004 21:10:25
Opiniones sobre paquetes v/s espirales Gerardo Pini General 4WD 13 31-12-1969 21:00:00
La franja horaria es GMT -3. Ahora son las 21:45:32.
