Antiguo 03-06-2005, 00:40:18   #1
Zorro
Predeterminado JEEP TK
para los fanaticos JEEP les cuento que mirando por ahi pille unas fotos espias del nuevo wrangler 2007. al parecer el TJ se va a hacer solo hasta el 2006, y de ahi en adelante pasa a ser TK.
aqui les dejo lo que dicen los gringos del nuevo jeek.
Jeep fans in the know are already aware that the Wrangler (TJ) will go away in 2006 and an all-new version, internally-dubbed "TK" will debut for the 2007 model year. Our eagle-eye spy shooters, braved feisty corporate car handlers and got these shots before being forced onto a highway off-ramp and losing the convoy!
The TK's shown here are traditional 2-doors, but a 4-door variant is also in the works. A possibly-fixed roof may appear, much like the Rescue concept from 2004, but it is hard to say. The rear corners would certainly suggest this, but a fold-down windshield might contradict the idea. It certainly does have a tailgate, though. Exposed door hinges hint that removable doors are going to stay.
We can expect the 2.4L 4 cylinder and 3.7L V6 to carry over from the current Jeep line as the 4.0L is finally given its walking papers.
Things of note that we noticed from these photos are the 2" receiver integrated into a metal bumper. A 2 inch receiver probably means a higher towing capacity than the current models. Perhaps a HEMI onboard? The exhaust pipe looks too small for a HEMI so these are probably V6 models. But who knows. Everyone knows DaimlerChrysler is hopped up on HEMI so it makes sense.
Also note in this photo the skinny arm on the driver-side rear.
In the third photo, it seems like there is more clearance under that flatter belly pan.
Lastly, what little we can see of the dash does show a more modern design with round air vents.
aqui las fotos:
Eso es lo que encontre, no se si alguien tiene mas info.
Antiguo 03-06-2005, 01:07:41   #2
Juan-Carlos
Avatar de Juan-Carlos
zorro seran estos
siempre e querido saber cual es la idea de andar trayendo los vehiculos tapados para no robar ideas???
es por eso??
honguito [/img]
Antiguo 03-06-2005, 10:35:37   #3
NicoD
Contactar con NicoD a través de MSN
Predeterminado Re: JEEP TK
Empezado por Zorro
Cambia el modelo cada 10 años, el CJ hasta el 86, el YJ hasta el 96 y ahora el TJ solo hasta el 06.
Ya vamos a ver que cambios trae el nuveo TK!!!!
NicoD está offline   Responder Con Cita
Antiguo 03-06-2005, 11:25:40   #4
pato castro
Avatar de pato castro
Al menos no es IFS...
Antiguo 03-06-2005, 11:37:28   #5
Rena
en españoool
Los ventiladores del jeep en el saber están ya enterados que el Wrangler (TJ) entrarán lejos en 2006 y una versión completamente nueva, "TK interno-doblado" principio por los 2007 años modelo. ¡Nuestros tiradores del espía del a'guila-ojo, braved a tratantes corporativos feisty del coche y consiguieron estos tiros antes de ser forzados sobre una apagado-rampa de la carretera y de perder el convoy!
Los TK's demostrados aquí son 2-doors tradicionales, pero una variante 4-door está también en los trabajos. Una azotea posible-fija puede aparecer, como el concepto del rescate a partir de 2004, pero es duro decir.
Las esquinas posteriores sugerirían ciertamente esto, pero un parabrisas plegable pudo contradecir la idea.
Tiene ciertamente una puerta posterior, aunque. La puerta expuesta abisagra indirecta que las puertas desprendibles van a permanecer.
Podemos esperar que el cilindro 2.4L 4 y el 3.7L V6 lleven encima de la línea actual del jeep mientras que el 4.0L finalmente se da sus papeles que caminan. Las cosas de la nota que notamos de estas fotos son el receptor del 2"integrado en un tope del metal. Un receptor de 2 pulgadas significa probablemente una capacidad más alta del remolque que los modelos actuales. ¿Quizás un HEMI onboard? Las miradas del tubo de escape demasiado pequeñas para un HEMI así que éstos son probablemente los modelos V6. Pero quién sabe.
Cada uno sabe que DaimlerChrysler está saltado para arriba en HEMI así que tiene sentido. También observe en esta foto el brazo flaco en la parte posterior del conductor-lado. En la tercera foto, se parece como allí es más separación debajo de esa cacerola más plana del vientre. Pasado, qué poco podemos ver de la rociada demuestra un diseño más moderno con las salidas de aire redondas.
:wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink: :wink:
Rena está offline   Responder Con Cita
Antiguo 03-06-2005, 13:56:26   #6
Mario Cerda
Avatar de Mario Cerda
Edad: 66
La traducción es pésima.... apuesto usastes uno de esos traductores on-line.
Mario
Antiguo 03-06-2005, 14:07:51   #7
Rena
www.altavista.com
Antiguo 03-06-2005, 14:27:14   #8
SVarasV
Jeepmaniac
Avatar de SVarasV
Ojalá no cambie mucho el diseño, ya el TJ lo encuentro muy bonito (será porque se parece al CJ :?: )
Espero que le hagan un cambio.....sacar los señalizadores de los tapabarros y volverlos a poner en la mascara.
Con respecto a las spy pics.....
Veo discos en las 4 ruedas, por lo que probablemente el modelo de la foto es top de linea
SI no me equivoco, veo un D44 atrás
En otra pagina leí que alomejor habría una versión V8 4,7
Antiguo 03-06-2005, 15:25:53   #9
La Berta
Avatar de La Berta
Empezado por SVarasV
dudo que sea el 4.7 , lo estan sacando de circulacion remplazandolo por el hemi 5.7
Antiguo 03-06-2005, 16:50:03   #10
SVarasV
Jeepmaniac
Avatar de SVarasV
Empezado por Paolo Celle
Lo sé, por lo mismo me suena razonable para deshacerse de stock de 4,7´s.
Alargar Jeep TJ; Aspectos Técnicos y de Diseño. Giovanni General 4WD 82 04-02-2009 17:51:29
DROP PITMAN ARM para JEEP WRANGLER TJ HAKUNA Venden - Partes y accesorios para 4X4 1 24-11-2008 21:09:36
Eres jeepero si.......... Gringo General 42 07-10-2005 03:05:07
jeep de pelicula madmax3...... Mad-Max General 7 04-08-2005 10:56:46
upsssss si no apago las luces el jeep tampoco se apaga.... =CicloN= Novatos 10 02-10-2004 05:46:14
La franja horaria es GMT -3. Ahora son las 02:47:23.
