Antiguo 17-10-2005, 17:33:42   #1
vodska
Avatar de vodska
Predeterminado que ejes son estos????
aca en iquique encontre un cherokee automatico con motor 2.5 me gustaria saber a que tipo de diferenciales corresponde , hasta que neumatico aguantan y con que relacion de coronas vienen, puesto que estoy pensando en ponerlos en mi samuka con spoa, me han dicho que aparentemento son iguales que los del 4.0lts.
de antemano gracias
Antiguo 17-10-2005, 17:41:48   #2
HAKUNA
Empezado por vodska
de antemano gracias
lo raro es el motor, tay seguro que es automático??, en mi vida había escuchado del 2.5 con caja automática..
en todo caso, los diferenciales son los mismos que el 4.0, dana 30 delantero high pinion y dana 35 trasero..
las relaciones, bueno, para el mecánico son 4:11..
hakuna
Antiguo 17-10-2005, 18:54:57   #3
Mac
http://jeephorizons.com/tech/xjstockspecs.html
Transmissions
Manual Transmissions
AX4 - 4 speed manual - manufactured by Aisin - used 84-86 with 2.5L I4 and 2.8L V6 engines
T4 & T5 - 4 & 5 speed manual - manufactured by Borg Warner - used 84-86 with 2.5L I4 and 2.8L V6 engines
BA10/5 - 5 speed manual - manufactured by Peugot - used only up to 89
AX5 - 5 speed manual - manufactured by Aisin - used with 2.8L V6 and 87+ with 2.5L I4
AX15 - 5 speed manual - manufactured by Aisin - used with 4.0L I6 engines
NV3550 - 5 speed manual - manufactured by New Venture - used in 00-01 in SE models with 4.0L I6 engines
Automatic Transmissions
Torqueflight 904 - 3 speed automatic - used 84-86 with 2.8L V6 and 2.5L I4 engines
30RH - 3 speed automatic - used with 2.5L I4 engine 94?-00
AW4 - 4 speed automatic, electronically controlled - manufactured by Aisin - used from 87-01 (87-91 models include a Power/Comfort button that adjusts the shift points).......
Axles
Front Axles
Dana 30 high pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear - used 84-99 (some axles through 91 are vacuum disconnect, 92+ are non-disconnect, 89-95 with ABS have 5-297x u-joints, all 95+ have 5-297x u-joints, all others have 5-260x u-joints)
Dana 30 low pinion - standard cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear, 5-297x u-joints - used 00-01
Rear Axles
(Note on Dana 35 axles sometimes referred to as Dana 35C - The "C" does not stand for c-clip. It stands for "custom" meaning it came from Dana unfinished.)
(Note on 8.25 axles - none of these axles were used on XJs with ABS brakes. If you have ABS, you have the Dana 35. Without ABS you could have either axle. 8.25 axles are c-clip)
Dana 35 non c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 84-89
Dana 35 c-clip - 27 spline, 1.18" diameter shafts, 7.58" ring gear, 2.62" axle tube - used 90-01
Chrysler 8.25 - 27 spline, 1.17" diameter shafts, 8.25" ring gear, 3" axle tube - used 91-96
Chrysler 8.25 - 29 spline, 1.21" diameter shafts, 8.25" ring gear, 3" axle tube - used 97-01
Dana 44 non c-clip - 30 spline, 1.31" diameter shafts, 8.5" ring gear, 2.75" axle tube - used 87-89 on some(not all) XJs equipped with towing package.
Gearing
3.07 - used with 4.0L engine / manual transmission
3.31 - only available on older (pre87?) 2 door XJs with "Fuel Economy" package
3.55 - used with 4.0L engine / automatic transmission
3.73 - found in some XJs with the towing package
4.10 - used with 2.5L engine usually, and older XJs with the "Off-Highway Vehicle" package.......
Espero te sirva ;-)
Antiguo 17-10-2005, 18:55:34   #4
aespinozah
Empezado por HAKUNA
hakuna
NO NECESARIAMENTE, podria tener atrás un Chrysler 8.25 y es harto mejor !
Antiguo 17-10-2005, 21:07:26   #5
vodska
Avatar de vodska
gracias mac con toda esa info me dejaste clarito asi que ahora a puro comprar ñlos ejes de cherokee lo unico que no me queda claro es hasta que medida de neumatico aguantan mas presisamente unos 33"
No hay caso con los Samukas....son filete estos chikitos!!!! Oscar Mejía Videos 5 08-06-2007 23:26:13
QUE TIPO DE YUGOS SON ESTOS...... ANGELLO ROTTA General 4WD 13 23-04-2005 19:17:34
Ejes TLC + transfer samuka, se puede? Claudio Vivero General 4WD 42 30-07-2004 15:11:33
Medidas ejes Gonzalo Bravo General 4WD 23 07-01-2004 16:41:10
LOS EJES MAS FIRMES SON... Gonzalo Bravo General 4WD 32 31-12-1969 21:00:00
La franja horaria es GMT -3. Ahora son las 19:34:58.
