Antiguo 09-03-2006, 17:05:39   #1
Sr.sj410
Avatar de Sr.sj410
Predeterminado Se Vende Handy Kenwood Th-k2 At
VENDO MI HANDY, USADO EN EXCELENTE ESTADO, CON CARGADOR Y MANUALES.
$110.000.-
PODRIA PERMUTAR POR ALGO INTERESANTE.
SALU2
Descripción
TH-K2AT
144 MHz- FM Transceiver
A triumph of advanced engineering and design Kenwood’s new TH-K2AT!
Even at first glance, it’s obvious that Kenwood’s stylish new TH-K2AT is in a class of its own. Though compact enough to fit snugly in either pocket or palm, it offers all the features necessary to make operation simple and sure. And despite its smart looks, this144MHz FM transceiver is tough enough to survive the rigors of outdoor use, while delivering superb performance. So roam freely while enjoying the clear, reliable communications for which Kenwood is renowned.
SOPHISTICATED DESIGN
In sharp contrast to other transceivers in this class, the smart navy-blue
TH-K2AT is sophisticated inside and stylish outside.
PRIORITY SCAN
By specifying a priority channel for scanning, you can be ready to receive on either of two different frequencies. Among the many other scan functions are VFO, MR, call, tone, CTCSS, DCS and program.
6-CHARACTER MEMORY NAMES
There are up to 100 memory channels available, or 50 if you use memory names (up to 6 alphanumeric characters to identify a channel). And in addition there are 8 special function memories.
WEATHER ALERT/RX (US only)
In addition to reception of the NOAA Weather Radio, this transceiver can warn you with an audible alert to emergency transmissions such as storm warnings.
BUILT-IN CTCSS, DCS
As well as CTCSS (42 sub-audible tone frequencies) and DCS (104 codes), the TH-K2AT offers a 1750Hz tone burst.
INTERNAL VOX
Convenient hand-free operation is possible when used with the optional KHS-21 headset.
HIGH-CAPACITY Ni-MH BATTERY
Supplied as standard is the environmentally friendly PB-43N Ni-MH battery, offering higher capacity than a
Ni-Cd battery. In high-power mode RF output is an impressive 5W.
LARGE BACKLIT LCD
The large 13-segment LCD display with backlighting ensures excellent visibility when using memory names or choosing settings.
PC PROGRAMMABLE
Handling multiple memory channels and memory names is easy from a PC (requires optional PG-4Y interface cable and free MCP-1A software). This is also convenient for copying settings to another transceiver. 13.8V DC-IN In addition to offering both battery-powered and 13.8V DC operation, the TH-K2AT can be used during battery-charging. Moreover, charging is faster than the previous models.
BACKLIT FRONT KEYPAD
Backlighting now makes key operation easy in low-light situations.
HIGH-GAIN ANTENNA
Shortened for easier carrying, the 4-inch antenna still offers high gain.
LARGE SPEAKER, LOUD AUDIO
Speaker output has been more than doubled to 400mW, ensuring clearer communications even in noisy environments.
RUGGEDIZED WEATHERPROOF CONSTRUCTION
This transceiver is built tough to meet the stringent MIL-STD 810 C/D/E/F standards for resistance to rain, vibration, shock and humidity. It also meets the international IP54 standard for dust and water resistance.
OTHER FEATURES
DTMF encode
Wide/narrow deviation selection
Memory channel transfer
Automatic simplex check
Automatic repeater offset
SMA antenna connector
Time-out timer
Auto power off
Antiguo 09-03-2006, 18:14:59   #2
Gonzalo Castro
banda corrida...cierto ????
Slds
Gonzalo Castro
Antiguo 09-03-2006, 18:24:17   #3
Sr.sj410
Avatar de Sr.sj410
Empezado por Gonzalo Castro
Slds
Gonzalo Castro
Asi es.
Banda corrida
Antiguo 09-03-2006, 23:38:40   #4
Sr.sj410
Avatar de Sr.sj410
Up.
Antiguo 10-03-2006, 09:44:20   #5
Sr.sj410
Avatar de Sr.sj410
OTRA FOTO (REFERENCIAL)
Antiguo 10-03-2006, 12:29:58   #6
Sr.sj410
Avatar de Sr.sj410
la podria cambiar por llantas de 10" de fierro pintadas o cromadas + una diferencia.
Antiguo 10-03-2006, 16:31:38   #7
Sr.sj410
Avatar de Sr.sj410
up !
Antiguo 10-03-2006, 16:39:42   #8
Sr.sj410
Avatar de Sr.sj410
Up
Antiguo 10-03-2006, 16:46:15   #9
madtoyo
Avatar de madtoyo
Contactar con madtoyo a través de MSN
Por Un Ancla Para Cuando Salgas A Jeepear Solo..mas $..
Te Interesaria..
madtoyo está offline   Responder Con Cita
Antiguo 10-03-2006, 21:12:20   #10
Empezado por madtoyo
Te Interesaria..
Jajaja o para cuando quiera vadear rios...:smile:
Saludos a la family;-)
Cargador para Handy Kenwood!!! Fantasma-4x4 General 4WD 0 25-10-2006 17:47:23
vendo handy Kenwood TH-22AT jotape Venden - Partes y accesorios para 4X4 0 27-09-2006 16:53:24
Como elegir un Turbo VSilva General 4WD 3 09-07-2006 15:37:54
Handy Kenwood Th-28 VHF y UHF (Dual band) Zankudo4x4 ® Venden - Partes y accesorios para 4X4 9 14-11-2005 10:30:38
2005 TWISTED ANDES JAMBOREE - Promo Gonzalo Bravo Paseos, Raids, Competencias y Eventos 4x4. 447 30-04-2005 03:59:37
La franja horaria es GMT -3. Ahora son las 07:20:40.
