Antiguo 22-04-2006, 22:17:24   #1
Giovanni
Predeterminado Nth Degree Front Slider Dana 44 Dana 35 (diff/pinion skid)
1/4" steel construction. It'll take a beating and keep you moving! Contours precisely to the axle housing hiding the flange lip but giving up NONE of your current ground clearance.
Bolt on! Most applications attach with three u-bolts (one over the pinion and one on each axle tube next to the trunions).
Protects Yoke & Drive Shaft The skid plate extends beyond the pinion to protect the spinning yoke and u-joint. This helps prevent expensive and debilitating breakage from contact with rocks, etc.
Differential and Pinion skid plate fits most Dana 44 & 35 axles
Keep wheeling longer with pinion and driveshaft protection
Don't get hung up because of your differential flange any more-Slide right over those rocks!
The main skid shell is made from 1/4” formed steel and is gusseted to create a rock-proof shield
Cut-outs at the rear edge of skid plate allow mud and water to drain and help minimize the accumulation of dirt, etc.
Nuevo, nuevo, nuevo...
Valor = $150.000.-
Antiguo 01-05-2006, 15:48:12   #2
Giovanni
bounce!
Antiguo 18-05-2006, 15:16:59   #3
Giovanni
Nadie..??? antes de instalarlo??????
Se reciben buenas ofertas por el protector de carter y por el protector de caja... todo Nth Degree Mobility nuevo!
Antiguo 20-07-2006, 00:57:30   #4
Giovanni
ya no se vende...
La franja horaria es GMT -3. Ahora son las 18:07:59.
