Antiguo 20-05-2006, 10:54:20   #1
Alberto Bravo
Avatar de Alberto Bravo
Predeterminado cherokee tips and tricks
navegando encontre esto.. esta super interesante.
USING YJ BRAKE LINES FOR LIFTED XJ
http://www.madxj.com/MADXJ/technical...eHosesOnXJ.htm
BRAKE JOBS/GUIDES
http://jeepin.com/features/drums/index.asp
http://jeepin.com/features/discs/index.asp
http://go.jeep-xj.info/HowtoFrontDisks.htm
http://go.jeep-xj.info/HowtoRearDrums1.htm
UPGRADING MASTER CYLINDER ON PRE 95 XJ's
http://www.madxj.com/MADXJ/technical...terUpgrade.htm
http://www.4x4wire.com/jeep/tech/bra...kes03/booster/
REAR DISC BREAKS ON A Chry Co 8.25 REAR AXLE
http://geocities.com/dcpaschal/mitch.html
http://cherokeekid5.tripod.com/zj_discs_on_a_xj.htm
http://www.akappler.com/document_ser...&doc=rear_disc
http://home.swbell.net/rriojas3/reardisk.html
REAR DISC BREAKS ON A D44 REAR AXLE
http://jeepin.com/features/cvdiscs/index.asp
REAR DISC BREAKS ON A D35 and D44 REAR AXLE
http://www.madxj.com/MADXJ/technical...rDiscsOnXJ.htm
**ENGINE MAINT, PERFORMANCE, AND UPGRADES**
POSSIBLE HIGH IDLE SOLUTION
http://www.olypen.com/craigh/idle.htm
COMMON MISFIRE CONDITION ON 00-01 (INJECTOR 3)
http://www.jeepforum.com/forum/showthread.php?t=72181
CPS REMOVAL
http://www.jeepforum.com/forum/showthread.php?t=197260
DIY OBA (On Board Air) USING STOCK AC COMPRESSOR
http://www.jeepforum.com/forum/showthread.php?t=194132
TB CLEANING THREADS/Link
http://www.off-road.com/jeep/cherok...ngine/tbody.htm
http://www.jeepforum.com/forum/showthread.php?t=143804
http://www.jeepforum.com/forum/showthread.php?t=154516
NON-HO TO HO SWAP, QUICK OVERVIEW
http://www.off-road.com/jeep/cheroke...p/engswap.html
INSTALLING A 99+ INTAKE ON A 91-98 HO HEAD
http://www.jeepforum.com/forum/showthread.php?t=215685
CHECKING AND ADJUSTING THE TPS ON A 87-90 4.0L
http://autorepair.about.com/library/faqs/bl232i.htm
READING THE OBDII DIAGNOSTIC CODES
http://www.getahelmet.com/jeeps/tech/codes/
http://www.allpar.com/fix/computer-codes.html
READING OBDI DIAGNOSTIC CODES
http://go.jeep-xj.info/HowtoECUcodes.htm
CHECKING THE COIL AND CPS TESTING PROCEDURES
http://autorepair.about.com/library/faqs/bl077g.htm
OIL IN AIR FILTER (BLOW BY) FIXES
http://www.off-road.com/jeep/cheroke...ltr/blowby.htm
http://www.off-road.com/jeep/cheroke...ver/cover.html
http://www.madxj.com/MADXJ/technical...ValveCover.htm
REPLACING FUEL FILTER ON A 97+
http://www.jeepforum.com/forum/showthread.php?t=138580
OIL PRESSURE SENDING UNIT TROUBLESHOOTING
http://www.olypen.com/craigh/pressure.htm
CONVERTING TO LARGER OIL FILTER
http://www.madxj.com/MADXJ/technical...Conversion.htm
FUEL INJECTOR O-RING REPLACEMENT
http://www.off-road.com/jeep/cheroke...ine/oring.html
CHANGING THE OIL ADAPTER O-RINGS
http://www.cardomain.com/memberpage/325707/4
http://www.lunghd.com/Tech_Articles...unt_O-Rings.htm
http://www.madxj.com/MADXJ/technical...Conversion.htm (covers removal and
install of Oil FIlter Adapter Housing).
MOTOR MOUNT REPLACMENT
http://www.jpmagazine.com/howto/31818/
http://www.off-road.com/jeep/cheroke...ine/engmounts/
http://www.off-road.com/jeep/cheroke...ts2/mount.html
http://jeepin.com/features/motormounts/index.asp
REAR MAIN SEAL REPLACEMENT
http://jeepin.com/features/rearmain/index.asp
BORING A HO (91+ 4.0L) THROTTLE BODY OUT TO 60mm
http://go.jeep-xj.info/HowtoTBboring.htm
http://www.cardomain.com/memberpage/325707/2
http://www.patricksnorton.com/cherok.../ThrottleB.php
HOMEBREWED SNORKLE/ DEEP WATER INTAKES
http://www.pirate4x4.com/tech/billav...el/snorkel.htm
http://www.madxj.com/MADXJ/technical.../AirIntake.htm
http://www.madxj.com/MADXJ/technical...tomSnorkle.htm
REMOVING STOCK AIR BOX SILENCER/VENTURI
www.go.jeep-xj.info/HowtoSilencer.htm
OPEN AIR (CONE FILTER) INTAKES
http://www.patricksnorton.com/cherokee/tech/afilter.php
http://www.cardomain.com/memberpage/325707/9
STROKER ARTICLES FOR THE 4.0L
http://www.angelfire.com/my/fan/stroker.html
http://www.madxj.com/MADXJ/technical...kerSummary.htm
http://www.madxj.com/MADXJ/technical...rokerCalcs.xls
http://www.bc4x4.com/tech/bryce/stroker/stroker.cfm
NUTTER BYPASS AND VARIOUS OTHER INFO ON CARB'D APPLICATIONS
http://www.m1911.org/cherokee_mods.htm
2.8L to 3.4L ENGINE SWAP
http://www.lunghd.com/Tech_Articles/...Project_XJ.htm
**COOLING**
3CORE RAD INSTALL
http://www.jeepin.com/features/gdi/index.asp
AUX FAN TEST WITH A JUMPER
http://www.fivezerofive.com/cpg132/...ls.php?album=81
INSTALLING NEW RADIATOR
http://www.go.jeep-xj.info/HowtoRadiatorFitting.htm
BURPING the COOLING SYSTEM
http://www.lunghd.com/Tech_Articles/...BurpAirMod.htm
CONVERTING THE CLOSED COOLING SYSTEM
http://www.geocities.com/chmwatson/F...ow-bottle.html
http://www.olypen.com/craigh/rad.htm
http://www.off-road.com/jeep/cheroke.../radiator.html
http://www.madxj.com/MADXJ/technical...stemSwitch.htm
WATER PUMP REPLACEMENT
http://jeepin.com/features/waterpump/index.asp
OVERRIDE SWITCH ON ELEC FAN
http://www.olypen.com/craigh/auxfan.htm
**BODY MODS**
FACTORY PAINT CODE LOACTION AND HOW TO READ IT
http://www.automotivetouchup.com/pai...tions.htm#chry
HOMEBREWED REMOVALABLE DOOR
http://www.myxj.net/tech/doorless/
(97+ year)http://xjfanatic.com/97doorless.php
TRIMMING FENDERS
http://www.madxj.com/MADXJ/technical...FenderTrim.htm
(Front Fender Trimming)
http://www.madxj.com/MADXJ/technical...rearfender.htm
(Rear Fender Chop)
http://jeepin.com/features/stageone/index.asp
http://rocklizardfabrications.com/fender_trimming.htm
http://www.patricksnorton.com/cherokee/tech/fenders.php
TJ FLARE INSTALL
http://home.earthlink.net/~jkorda/mods/tjflares.html
FENDER FLARE RELOCATING
http://www.madxj.com/MADXJ/technical...nderFlares.htm
INSTALLING NEWER (97+) DOOR SEALS ON OLDER XJ
http://www.madxj.com/MADXJ/technical.../DoorSeals.htm
HOOD VENTS
http://www.ericsxj.com/vents.htm
http://www.patricksnorton.com/cherok...h/hoodvent.php
Antiguo 20-05-2006, 10:55:08   #2
Alberto Bravo
**INTERIOR AND ELECTRICAL**
DIY IGN KILL SWITCH
http://autospeed.drive.com.au/cms/article.html?&A=0059
HEADLINER REPARE INSTALL
http://www.lunghd.com/Tech_Articles/.../Headliner.htm
http://www.wlsheadliners.com/tutorials/cherokee/
WALMART OVERHEAD LIGHTS MOD
http://www.jeepforum.com/forum/showt...=walmart+light
HEADLIGHT UPGRADES
www.patricksnorton.com/cherokee/tech/hlights.php
http://www.patricksnorton.com/cherok...h/hlights2.php
INTERIOR STORAGE DECK
http://www.ericsxj.com/storage.htm
http://www.jeepforum.com/forum/showthread.php?t=197251
INTERIOR STORAGE DECK (With the add-on for leveling out cargo with seat down)
http://www.yuccaman.com/jeep/storage.html
97+ QUARTZ CLOCK INSTALL IN A PRE 97XJ
http://www.jeepforum.com/forum/showthread.php?t=64514
http://www.go.jeep-xj.info/HowtoDashClock.htm
CB RADIO
http://www.patricksnorton.com/cherokee/tech/CB.php
SPEAKER UPGRADES / SUB ENCLOSURES
http://www.jeepforum.com/forum/showthread.php?t=97186
LED BACKLIGHTING FOR GAUGE PANEL
http://www.jeepforum.com/forum/showthread.php?t=109945
GAUGE SWAP
http://www.jeepin.com/features/gaugeswap/index.asp (88-90 to 91-95 cluster swap)
http://www.jeepforum.com/forum/showthread.php?t=109945 (LED dash lights)
ON BOARD AIR INSTALLATION
http://www.electronicimpulse.net/~v...ep/tech/OBA.htm
http://www.rocklizardfabrications.com/power_tank.htm
http://www.ericsxj.com/oba.htm
UPGRADING CHARGING SYSTEMS (slow starts and better charging)
http://www.olypen.com/craigh/charge.htm
http://www.bc4x4.com/tech/2004/jeepalt/
http://www.patricksnorton.com/chero...ch/Batcable.php
DUAL BATTERY
http://www.pirate4x4.com/tech/billav...tery_setup.htm
http://www.4wdandsportutility.com/te...4wd_batteries/
http://www.http://madxj.com/MADXJ/te...Relocation.htm
HVAC BLOWER FIX (if motor speed selector not working)
http://www.geocities.com/chmwatson/F...elink_fix.html
**Maintenance**
AXLE FLUID CHANGE
http://www.getahelmet.com/jeeps/maint/diff_fluid/
http://www.off-road.com/jeep/cheroke...ept/gb/gb.html
http://www.stu-offroad.com/misc/diff-1.htm
SPARK PLUG REPLACEMENT ON 00 and 01 4.0L ENGINES
http://jeephorizons.com/tech/spark.html
CHANGING SPARK PLUGS ON A 87-98
http://www.**********.org/changeplugs.htm
BELTS, BRAKE FLUID, POWERSTEERING, AND TC
http://go.jeep-xj.info/HowtoService.htm
AW4 TRANS SERVICE
http://go.jeep-xj.info/HowtoAutoService.htm
FRONT AND REAR BRAKES
Serpentine belt routing 95
http://autorepair.about.com/library/faqs/bl453h.htm
**WHEEL AND TIRE TECH**
GENERAL WHEEL INFO
http://www.rsracing.com/tech-wheel.html
Última edición por Alberto Bravo fecha: 20-05-2006 a las 11:11:18
Antiguo 20-05-2006, 11:13:07   #3
Alberto Bravo
**TECH DOWNLOADS/ OFFROAD TECHNIQUE/LOCKER MANFACTURER LINKS**
Tech Manuals 88, 93, 00
http://www.lunghd.com/Downloads_and_Links/Downloads.htm
MANUALS and VARIOUS
http://www.pirate4x4.com/tech/billavista/PDFs/
AW4 TROUBLESHOOTING GUIDE
http://members.fortunecity.com/90limited/
4WHEEL TERRAIN TECHNIQUES
**Not all XJ stuff, but general refrences. Some trick may not work with ECU vehicles.**
http://www.pps.net.au/4wdencounter/4wdtech/4wdtech.html
http://4wheeldrive.about.com/cs/off...aa020401a_4.htm
http://4wheeloffroad.com/techarticles/17158/
GENERAL OFFROAD TECH
http://www.4x4now.com/4wht.htm
http://4wheeldrive.about.com/gi/dyn...%2Fspotting.htm
http://4wheeldrive.about.com/gi/dyn...oa dguide1.htm
LOCKER MAKER LINKS
http://www.offroadlockers.com
http://www.trachtech.com
http://www.traction.eaton.com
http://www.arbusa.com/
http://www.powertrax.com/
LOCKER VENDORS
http://www.differentials.com/catalog.html
http://www.drivetrain.com/Powertrex.html
**LIFTS**
TIRE LIFT COMBO
Stock lift:
http://jeepforum.com/forum/showthread.php?t=91208
http://jeepforum.com/forum/showthread.php?t=82869
Lifted fitment:
http://jeepforum.com/forum/showthread.php?t=90893
Overview of various lifts/tires:
http://jeepforum.com/forum/showthread.php?t=45602
TIRE SIZE COMPARISION/CONVERSION CALCULATOR
http://www.1010tires.com/TireSizeCalculator.asp
www.dakota-truck.net/TIRECALC/tirecalc.html
2" BUDGET BOOST
http://www.patricksnorton.com/cherokee/tech/boost.php
HOME BREWED BB LIFT
http://www.rocklizardfabrications.co...dget_boost.htm
http://www.go.jeep-xj.info/HowtoFrontSpacer.htm
http://www.go.jeep-xj.info/HowtoRearSpacer.htm
ROUGH COUNTRY/HECKETHORN (covers AAL install)
http://www.off-road.com/jeep/cheroke...t/hrclift.html
SKYJACKER 3" LIFT
www.polytropia.com/cherokee/suspension.html
OME 3.5
http://www.off-road.com/jeep/cheroke...ME/ome-lw.html
RE 5.5" HD LIFT
http://www.patricksnorton.com/cherok...h/re55lift.php
TNT LA KIT
http://www.projectxj.com/mods/long.arms.htm
S10 LEAF SWAPS
http://www.naxja.org/forum/showthread.php?t=50083
DAKOTA LEAF SWAPS
http://www.lunghd.com/Tech_Articles/...udget_Lift.htm
Antiguo 20-05-2006, 11:14:45   #4
Alberto Bravo
**SUSPENSION MODS AND FIXES**
REDRILLING STOCK TRAC-BAR MOUNT AFTER LIFT
http://www.go.jeep-xj.info/HowtoTrackbar.htm
HOMEBREWED LONG ARMS
http://www.xjworld.4wdriver.com/longarm.htm
DEATH WOBBLE FIXES
http://www.kevinsoffroad.com/techart...athwobble.html
http://www.yuccaman.com/jeep/dw.html
HOME BREWED BPE FRONT AND REAR
http://www.jeepforum.com/forum/showthread.php?t=91472
http://www.lunghd.com/Tech_Articles/.../Rear_BPEs.htm
REAR SHOCK MOUNT RELOCATION (higher mount more ground clearence)
http://www.go.jeep-xj.info/HowtoRearShockM.htm
REAR UPPER SHOCK MOUNT REPAIR/ OPTIONS (BPE's)
http://www.rocklizardfabrications.co...ock_mounts.htm
SHOCK LENGTH GUIDE FOR DIFFERENT LIFTS SIZES (other tech too)
http://members.aol.com/Stvns/XJhelp2.html
QUICK DISCONNECTS
http://www.patricksnorton.com/cherokee/tech/qdcs.php
ADJUSTING BUMPSTOP LENGTH
http://www.rocklizardfabrications.co..._Bumpstops.htm
HOMEBREWED TC DROP BRACKET
http://www.go.jeep-xj.info/HowtoTCdrop.htm
LCA and UCA LENGTHS FOR DIFFERENT LIFT SIZES
http://www.yuccaman.com/jeep/re_db.html
**FRONT AND REAR AXLES**
FRONT AND REAR AXLE GUIDE
http://www.yuccaman.com/jeep/gear1.html
http://memimage.cardomain.net/member...7_182_full.jpg
GEAR RATIO CHART AND FORMULA FOR TIRE SIZES
http://www.superlift.com/library/gears.asp
http://gs.tolan-hoechst.com/tirecalc.htm
FRONT D30 AXLE and STEERING
XJ FRONT LEAF CONVERSION
http://www.pirate4x4.com/tech/billav...sion/leafs.htm
http://www.patricksnorton.com/cherokee/tech/leafs.php
ZJ TO XJ TIE ROD CONVERSION (couple of TJ articles, but XJ and TJ use same steering linkage)
http://www.jeephorizons.com/tech/tjtierod/
http://www.stu-offroad.com/misc/tierod-1.htm
http://members.rennlist.com/gman/jeep/
TIE ROD END DUST BOOT REPLACEMENT (poly boots can be bought at most auto parts stores if you can't find factory replacements)
http://www.go.jeep-xj.info/HowtoTieRod.htm
STEERING STABILIZER REPLACEMENT
http://www.4x4xplor.com/steeringstabilizer.html
STEERING
http://www.off-road.com/jeep/tech/axle/yj-tierod.htm (beefing up factory Tie Rod)
http://www.xjworld.4wdriver.com/steering.htm
STEERING STOP ADJUSTMENT (On a TJ, but same set up as the XJ knuckles)
http://www.4x4xplor.com/steerstop.html
DANA30 HOME_BREWED POSI_LOCK SYETEM AND VACUUM DIAGRAM
(!)http://home.earthlink.net/~stevenschreiber/jeep/
http://www.4x4wire.com/dodge/tech/solid_axle_cad/
FRONT HUB REPLACEMENT
http://www.off-road.com/jeep/cheroke...ing/index.html
FRONT HUB CONVERSION
http://www.patricksnorton.com/cherokee/tech/hubs.php
SWAPPING 1 PIECE TJ AXLES INTO A VAC DISCO D30
http://www.stu-offroad.com/axle/yjd3...jconvert-1.htm
XJ DANA30 FRONT AXLE SEALS/ 297-X UJOINT UPGRADE/ UJOINT REBUILD
http://www.madxj.com/MADXJ/technical...97andSeals.htm
http://www.4x4wire.com/tech/axle/ujoint/
http://www.jeepin.com/features/ujoint/index.asp
http://www.patricksnorton.com/cherokee/tech/ujoints.php
http://www.patricksnorton.com/cherok.../tubeseals.php
LOCK RITE LOCKER INSTALL (TALL GEARS) WITH CARRIER REMOVAL STEPS
http://www.jeepaholics.com/tech/lrhubs/default.htm
http://www.4x4wire.com/jeep/tech/axle/lr00a/
REAR AXLE
XJ DANA44 AXLE SWAP
http://www.pirate4x4.com/tech/billav...uildup/D44.htm
RING AND PINION INSTALL (GEARS) ON A CHRY-CO 8.25 AXLE
http://www.jeepforum.com/forum/showthread.php?t=109859
AXLE PIC CHART FOR COMMON AXLES
http://www.jeepforum.com/forum/atta...tachmentid=3560
PICS OF A D35 AND A CHRYSLER 8.25 REAR AXLES
http://www.jeepforum.com/forum/showthread.php?t=88078
FORD 8.8 REAR AXLE SWAP INFO
http://members.cox.net/rough-riders/...8/ford8_8.html
http://www.bc4x4.com/tech/2003/xj88/
http://www.4x4wire.com/jeep/tech/axle/ford8_8/
http://xjfanatic.com/ford88.php
http://www.jedi.com/obiwan/jeep/ford88.html
Antiguo 20-05-2006, 11:16:21   #5
Alberto Bravo
**RECOVERY AND PROTECTION**
CRUDE DIY TOWHOOK BRACKET SCHEMATIC
http://www.bc4x4.com/tech/2004/xjhook/
TOW HOOK INSTALLATION
http://www.patricksnorton.com/cherok...hookbumper.php
http://www.off-road.com/jeep/cheroke...t4x4hooks.html
http://www.sonicjay.com/jeep/97up-xj-hooks.pdf
SKIDROW TRANSFER CASE SKID
http://www.patricksnorton.com/cherok.../tcaseskid.php
TOMKEN TRANS SKID
http://www.ericsxj.com/tomken.htm
MOPAR GAS TANK SKID / RECEIVER HITCH
http://www.patricksnorton.com/cherok.../hitchskid.php
BUMPER INSTALLATION (FRONT)
http://www.patricksnorton.com/cherokee/tech/BPI.php
**TRANSMISSION AND TRANSFER CASE**
General AX5 INFO
http://www.novak-adapt.com/knowledge/ax5.htm
General AX15 INFO
http://www.novak-adapt.com/knowledge/ax15.htm
General AW4 INFO
http://www.novak-adapt.com/knowledge/aw4.htm
GENERAL NP231 INFO
http://www.novak-adapt.com/knowledge/np231.htm
GENERAL NP207 INFO
B&M TRANS TEMP GAUGE INSTALL
http://4x4trailhunters.com/article.php?id=12
http://jeepin.com/features/tranny_temp_gauge/index.asp
TRANS GEAR RATIOS
AX15- http://www.off-road.com/jeep/tech/trans/ax15.html
AX5- http://www.off-road.com/jeep/tech/trans/ax5.html
BA10/5- http://www.off-road.com/jeep/tech/trans/ba10.html
TF904/909- http://www.off-road.com/jeep/tech/trans/tf904.html
AW4- under best auto trans http://www.off-road.com/jeep/cheroke.../jeepspeedfaq/
NUETRAL SAFETY SWITCH REBUILD
http://jeepin.com/features/nss/index.asp
http://www.dirtdevils.org/briantechtippage.htm
AW4 TRANSMISSION OVERRIDE SWITCH
http://www.jeepbarracks.com/modules....article&sid=19
http://www.go.jeep-xj.info/HowtoAutoSwitch.htm
http://jeepforum.com/forum/showthread.php?t=234510
SPEEDO GEAR SWAP FOR RECALIBRATING SPEEDO (BIGGER TIRES)
http://jeepin.com/features/speedogear/index.asp
http://www.off-road.com/jeep/cheroke...do/speedo.html (note: chart #'s in this article are wrong.)
NP231 PARTAIL OVERHAUL
http://4x4trailhunters.com/article.php?id=20
SYE (Slip Yoke Eliminator) NP231 TC (XJ and YJ/TJ use the same methods for install)
ADDITIONAL AA/PORC SYE INFO
http://www.jeepforum.com/forum/showthread.php?t=212704
AA- http://www.4x4wire.com/jeep/reviews/aasye99/
http://jeepsunlimited.com/modules.p...=article&sid=71
RE 88-95- http://www.dorianjepsen.com/wrangler/syekit/index.php
RE 96-01- http://www.yuccaman.com/jeep/sye.html
http://www.off-road.com/jeep/cheroke...slip-yoke.html
Tom Woods- http://www.polytropia.com/cherokee/sye.html
JB- http://www.rockcrawler.com/techrepor...iner/index.asp
http://www.jpmagazine.com/howto/29623/
http://7slotgrille.com/tech/sye2/
SYE (Slip Yoke Eliminator) NP242 TC
RE- http://www.polytropia.com/cherokee/sye.html
http://www.angelfire.com/nc3/84jeepxj/sye.html
JB CONVERSIONS "SHORTY" SYE
http://www.jeepin.com/features/supershorty/index.asp
Antiguo 20-05-2006, 13:06:30   #6
G Pereira
Avatar de G Pereira
no te has pajeado nada con el cherokee
:smile: :smile:
Antiguo 20-05-2006, 13:19:16   #7
Alberto Bravo
Empezado por G Pereira
:smile: :smile:
jjajaja.. ;-) .
slds.
Antiguo 20-05-2006, 13:56:15   #8
S.O.S.
Avatar de S.O.S.
oye gordi
encontraste donde digan como disminuir el consumo!!!!
jajajaja
Antiguo 20-05-2006, 17:36:59   #9
Alberto Bravo
Empezado por s.o.s
oye gordi
jajajaja
nop...pero apenas encuetre algo, te paso el dato pa la seudo-tacoma :razz:
Última edición por Alberto Bravo fecha: 20-05-2006 a las 17:46:11
La franja horaria es GMT -3. Ahora son las 19:55:29.
