Antiguo 14-05-2007, 14:59:55   #1
AndR3Z
Predeterminado 1GR-FE completo
1GR-FE 4.0L V6
The 1GR-FE is the 4.0L version. Bore is 94 mm and stroke is 95 mm. Output is 236 hp (183 kW) at 5200 rpm with 266 lb-ft (382 Nm) of torque at 4000 rpm on 87 octane, and 239 hp at 5200 rpm with 278 lb-ft at 3700 rpm on 91 octane. This engine features Toyota's single VVT-i, variable valve timing, system and a compression ratio of 10.0:1. Inside, the 1GR uses a taper-squish combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are such 2 passages for each bank for a total of 4. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
Está completo con la caja automatica 4x2, con estanque con bomba de bencina. todos el ramal completo, ecu
llegar he injertar
es de una 4runner 2005 en desarme.
fotos no tengo aun, la 4R la desarmo yo por lo q no se corta ningun cable. muy poco kilometraje.. bien rapido el aparato
$1.500.000 por el motor y caja
Antiguo 14-05-2007, 16:05:15   #2
AndR3Z
Predeterminado Re: 1GR-FE completo
recibo Ford V10, Diesel grande (Arriba de 4.0) mas lucas en parte de pago...
Antiguo 14-05-2007, 20:01:50   #3
Pez Gordo
Avatar de Pez Gordo
yo manejo ese motor a diario y es una paja , en una hilux debe volar, lo unico mejor debe ser un v8 lexus , nada mas, fierrazo
Antiguo 14-05-2007, 20:30:26   #4
DESERTICO
Avatar de DESERTICO
Está barato...acá en la zofri te saldía al mismo precio
Antiguo 14-05-2007, 20:35:52   #5
IsHA
Avatar de IsHA
Contactar con IsHA a través de MSN
entrara en un samuka ???
IsHA está offline   Responder Con Cita
Antiguo 14-05-2007, 20:54:27   #6
AndR3Z
Empezado por IsHA
si entra un v8 ford q es grandote pq no va a entrar un v6 toyota q es mas chico
Antiguo 14-05-2007, 21:11:06   #7
GabrielSov
Contactar con GabrielSov a través de MSN
cuantos kms tiene?
Sld
GabrielSov está offline   Responder Con Cita
Antiguo 14-05-2007, 21:19:59   #8
Arriero
Avatar de Arriero
Empezado por GabrielSov
cuantos kms tiene?
Sld
en que estai pensando compadre!
Antiguo 14-05-2007, 21:34:16   #9
AndR3Z
no estoy seguro.. como 30.000km parece.
Antiguo 14-05-2007, 21:35:22   #10
AndR3Z
Empezado por Arriero
pensandolo bien.. quedaria ideal para un buggy pa atacama
te vendo completo en 2 palos.. motor.. caja.. chassis.. eje cardanes
disco en las 4.. pernadura toyota.. uff.. te podi hacer don buggy aqui
La franja horaria es GMT -3. Ahora son las 11:15:33.
