Antiguo 19-08-2009, 01:51:12   #1
Negro34
Predeterminado Leveling kit
hola, aguien tiene algn dato para un leveling kit para una chevy ZR2 2000?
de antemano gracias
Negro34 está offline   Responder Con Cita
Antiguo 19-08-2009, 02:01:10   #2
Alberto Bravo
Avatar de Alberto Bravo
Predeterminado Re: Leveling kit
Empezado por Negro34 Ver Mensaje
de antemano gracias
esto aparece en un foro gringo de zr2.
"Leveling Kits" for all GM trucks are just re-indexed torsion bar keys. In all actuality you dont even need to keys to kill your front end by trying to level the truck out.
Cranking the t-bars up all of the way with the stock keys will kill your front end, How fast it depends on but it will be highly accelerated.
Now for example, You crank the torsion bars up all of the way with the stock keys(bolts all of the way flush), You gain 2 inches of lift in the front end. Now you put re-indexed torsion bar keys in and you crank the torsion bars all of the way up again, With the bolts flush you would probably get 3/4 inches of lift. This is done by the different keys but doing this will kill your front end even faster.
The fullsize chevy's can handle the torsion bars being cranked alot better than the zr2's.
La franja horaria es GMT -3. Ahora son las 17:33:47.
