Antiguo 07-12-2011, 22:18:48   #1
Pato Leguía
Avatar de Pato Leguía
Predeterminado Jayco 1207 ahora Shamrock by Forest River
Decidí hacer este post para mostrar algunas pequeñas modificaciones que le haré al Camper y a su tow rig, algunos chiches que le iré agregando y los tips que vaya aprendiendo e implementando:
Primero, las especificaciones (en Inglés, ya que me da lata traducir ):
2009 Jayco Jay Series 1207
Unloaded vehicle weight (lbs.) 1,935
Approx. hitch weight (lbs.) 195
Gross vehicle weight rating (lbs.) 2,950
Cargo carrying capacity 1,015
Travel length 16' 2"
Campsite length 23' 4"
Approx. travel height 60"
Fresh water capacity (gals.) includes water heater 23
Sleeping capacity 6-8
30Ft 30 amp power cord
Hookup for city water
12V electrical system with 20-amp. 110V converter (Convertido a 220 V)
17 gal. fresh water system with 12V demand pump
Water heater bypass system
TorFlex® independent torsion axle suspension
Automotive styling rear caps
Aluminum exterior sidewalls
Entrance door caddy
Wide-body construction
Vinyl, spare tire cover
Tent attachment velcros around entrance door
Spare tire and tire carrier
Self-storing step
Scratch resistant, embossed aluminum finish on exterior
Patio light with amber lens
Outside shower
One-piece high-density polyethylene wheel wells
Lifter post covers integrated into tent
Leveling jacks and heavy-duty A-frame construction
Jayco's original, fully enclosed lifter system (same design used since 1968)
E-Z Lube® axles
Floor is undercoated and constructed of edge-sealed Structurwood™
Extrusions for box top are painted (powder-coated) white with white corner caps
Entrance door is 1-piece construction
Entrance door access with roof lowered
E-Coat™ protected frame
Domed, fiberglass roof with no center seam and prepped for bike carrier
Crank-down stabilizer jacks w/ sand pads
DURATEK™ water-repellent sectionalized tent
Bumper made with welded steel construction
110V G.F.C.I. protected exterior receptacle
15 lts. propane gas bottle
14" x 14" roof vent
13" C-range tires
Exterior entrance door storage with securement strap
Rounded wheel wells
Self-storing screen door
Silver wheel rims
Bed bases are undercoated
Stainless steel carryout stove (2-burner, depending on model)
Acrylic sink and faucet
Tray for silverware
Spice rack
Carry-out dinette table
Automatic cut-off switch for interior lights
12V high-intensity lighting
Heavy-duty entrance door securement latches
Modern interior designed and made by Jayco®
110V G.F.C.I. protected interior receptacle
Granite-look countertop
Cup holders installed throughout
C-clamp connection on tent supports
Brushed nickel hardware
Booth dinette
Vinyl flooring wall to wall
SoftShade™ window shades and valances
Privacy curtains for end-bunks
Non-sliding, 4" deep cushions for dinette with reversible EZ-clean™ vinyl backs
Mildew-resistant aluminum ceiling
Hinged dinette seat bases
Coordinated furniture, designed and made by Jayco®
Manchester Oak hardwood flat panel cabinetry
Drawers made of real wood with nylon guides
Door pulls with roller catch
Tinted vinyl windows
Powder-coated white bunk end bows with adjustable tension tent supports
Bed flaps that cover edge of bed
Breakaway switch
Dual hitch safety chains
Fire extinguisher
Propane alarm
Carbon monoxide alarm
Customer Value Package
2-cu.ft. 3-way gas/electric refrigerator (110V/12V/Propane)
Bunk-end fan lights (2)
Self-storing awning made by Jayco®
Water purification system
13500 BTU A/C
Última edición por Pato Leguía fecha: 18-07-2012 a las 01:55:31
Antiguo 07-12-2011, 22:20:40   #2
Predeterminado Re: Proyecto: Jayco 1207
empezemos con alguna foto del estado actual ....
Antiguo 07-12-2011, 22:28:42   #3
Julio Irigoyen Neol
Avatar de Julio Irigoyen Neol
Edad: 61
Empezado por JPVM Ver Mensaje
Hola Pato, atento a los avances.
Julio
PD: algun dia pondre mi proyecto.
Antiguo 07-12-2011, 22:36:15   #4
Pato Leguía
PLANTA:
  1. Cama Queen
  2. Cama King
  3. Comedor
  4. Lavaplato
  5. Encimera (portable, se puede instalar afuera)
  6. Refrigerador
  7. Comedor en U (no tengo la mesa aún)
Antiguo 07-12-2011, 22:53:49   #5
Pato Leguía
Tow Rig:
Chevy Tahoe 2001
5.3 Vortec V8
4 puertas
Fotos del conjunto:
Antiguo 07-12-2011, 23:17:10   #6
Boris Aguilera Manzano
Avatar de Boris Aguilera Manzano
Estaré muy atento
Eso si me gustaría mas detalle de lo indica que tiene su carro para ver de aquello tiene el mío..
Por ejemplo, para que usas el purificador de agua?, la pregunta es obvia, pero para que??.
Saludos, estaré atento y suerte
Boris Aguilera Manzano está offline   Responder Con Cita
Antiguo 07-12-2011, 23:21:40   #7
Pato Leguía
Accesorios y tonteritas:
Acople rápido de manguera:
Aislante térmico para debajo de las camas:
Alfombra:
Cajas Organizadoras:
Colchonetas Goma EVA Aluminizadas (Muy importante). Son para aislar ventanas y evitar pérdidas térmicas.
Microondas y aspiradora
Antiguo 07-12-2011, 23:23:26   #8
Pato Leguía
Empezado por Boris Aguilera Manzano Ver Mensaje
Estaré muy atento
Boris, te parece que crees un post de tu Carro...así empezamos con estos proyectos en el foro? y podemos ir compartiendo experiencias!
(en qué ciudad estás?)
Antiguo 07-12-2011, 23:35:36   #9
Pato Leguía
Pasador anti golpeteo:
Uploaded with ImageShack.us
Anillo anti vibración:
Extensión de espejo:
By patov6 at 2011-12-07
Secador de loza
Cobertor para cuando se guarde:
Última edición por Pato Leguía fecha: 07-12-2011 a las 23:42:11
Antiguo 08-12-2011, 00:13:10   #10
Kruger
Avatar de Kruger
Que buen proyecto, estaremos atentos para sacar ideas pal futuro....
que aro y tamaño de ruedas tiene el carro?, no entraran unas 33 como para los caminos de tierra??
La franja horaria es GMT -3. Ahora son las 22:26:36.
