Antiguo 15-04-2013, 15:00:54   #1
Monster4x4
Predeterminado Oferta ¡¡¡¡¡¡¡
COMPRESOR VIAR MODELO 300 P 150 PSI + REAPARADOR DE PINCHAZO ARB $ 99.000
Atte
Tipo de Archivo: jpg ARB10000010.jpg (33,4 KB, 949 visitas)
Tipo de Archivo: jpg viair_30033.jpg (55,1 KB, 948 visitas)
Monster4x4 está offline   Responder Con Cita
Antiguo 15-04-2013, 23:29:07   #2
hernan urbina
Avatar de hernan urbina
Contactar con hernan urbina a través de MSN
Predeterminado Re: Oferta ¡¡¡¡¡¡¡
Empezado por Monster4x4 Ver Mensaje
Atte
Tremenada OFERTA¡¡¡¡¡¡¡¡¡¡¡¡¡¡
hernan urbina está offline   Responder Con Cita
Antiguo 17-04-2013, 14:54:42   #3
jorge avaria
De cuantos litros es...???
Antiguo 23-04-2013, 11:16:23   #4
Monster4x4
Empezado por jorge avaria Ver Mensaje
300P is a larger portable compressor kit that is capable of inflating up to 33-inch tires easily by simply clamping the power leads to your battery, connecting the tire chuck to the valve stem and turning the unit on. Tire pressure can be checked using the 5-in-1 Inflator/Deflator inline pressure gauge.
Features
- Aluminum Sand Tray with Vibration Isolators
- Deluxe Dual Compartment Carry Bag
- 3-pc. Inflation Tips Kit
- 5-in-1 Inflator/Deflator with Inline 100 PSI Gauge
- Dual Battery Clamps
- 40-amp Inline Fuse Holder
- Power Cord: 8 ft. / Air Hose: 25 ft. Specifications
12-Volt
Permanent Magnetic Motor
Duty Cycle: 33% @ 100 PSI
Max. Working Pressure: 150 PSI
Max. Amp Draw: 27 Amps
Net Weight: 8.70 lbs.
Note:
The air hose supplied with this kit may become brittle from prolonged exposure to UV/sunlight. - Stow when not in use. Never allow the hose to come into contact with the head of the compressor during use (melting hazard). The use of the included air hose is not recommended in sub zero or freezing conditions.
Tech Links
Dimensional Drawings
Instruction Manual
Performance Data
PSI CFM A BAR LPM A 0 2.40 17 0 67.5 17 10 1.94 21 1.0 52.0 22 20 1.76 23 2.0 45.5 25 30 1.62 25 3.0 40.5 26 40 1.48 26 4.0 35.5 27 50 1.34 27 5.0 30.5 27 60 1.24 27 6.0 26.5 27 70 1.13 27 7.0 23.5 26 80 0.99 27 8.0 19.0 25 90 0.92 27 9.0 15.5 24 100 0.85 26 10.0 14.0 22 110 0.74 25 120 0.63 25
130 0.56 24 140 0.53 22 150 0.46 21 *Supply Voltage: 13.8 Volts
Fill Rates
31" x 10.5" Fill Rate 0 To 30 PSI 3 Min. 25 Sec. 15 To 30 PSI 2 Min. 00 Sec. 33" x 12.5" Fill Rate 0 To 30 PSI 5 Min. 00 Sec. 15 To 30 PSI 2 Min. 45 Sec. Saludos ¡¡¡¡¡¡¡
Antiguo 03-09-2013, 22:35:25   #5
JUAN TORO (RUDY)
Contactar a JUAN TORO (RUDY) a través de Yahoo
pelaito contesta el cel.saludos
JUAN TORO (RUDY) está offline   Responder Con Cita
Antiguo 13-09-2013, 15:14:47   #6
hermanoslatournerie
Buenas tardes los compresores sirven para neumatico de 40".
Antiguo 23-09-2013, 19:05:36   #7
Monster4x4
Empezado por hermanoslatournerie Ver Mensaje
Saludos , estos compresres tienen 150 psi los modelos 300 p y 400p su diferencia :
300p , 30 minutos de trabajo infla sin problema un 36x13.5r18 (probado a morir y aun funcionan andan varios compresores marca VIAIR y ninguno se a devuelto muy buen producto ) se aceptan comentarios de las personas que lo tienen.
400p , 40 minutos de trabajo , de 0 a 30 psi en un neuma de 35x12.5r15 4.5 minutos , deveria sin problema inflar un 40 su valor es de $ 120.000 c/iva
Atte
La franja horaria es GMT -3. Ahora son las 17:55:59.
