Antiguo 11-07-2013, 11:38:48   #1
CHINO GONZALEZ
Avatar de CHINO GONZALEZ
Predeterminado Crucetas Spicer Dana 44 5-760X
Vendo par de crucetas Dana Spicer 5-760x traidas desde USA.
Sirven para los ejes Dana 44.
Estas crucetas son una nueva version de Dana Spicer y segun dicen aguantan un 30% mas que las crucetas normales. Ademas de ser originales Dana Spicer.
http://www.4wheeloffroad.com/product...u_joint_jeeps/
http://www.quadratec.com/products/52302_102.htm
Estan nuevas en caja.
$60.000 el par.
No se venden por unidad ni se baja el precio ya que me salio muy caro el envio.
CHINO GONZALEZ está offline   Responder Con Cita
Antiguo 11-07-2013, 12:24:24   #2
CHINO GONZALEZ
Predeterminado Re: Crucetas Spicer Dana 44 5-760X
Tambien sirven para Dana 30.
Application Chart
1972 - 1991 Chevy K-5 Blazer & GMC Jimmy... all 1 3/16 inch diameter bearing cap
1972 - 1986 Chevy K-10 & K-20, GMC K-15, K-25 Pick-Up... all 1 3/16 inch diameter bearing cap
1972 - 1993 Dodge W100, W150, W200, W250... all 1 3/16 inch diameter bearing cap
1973 - Dodge W300, W350... all 1 3/16 inch diameter bearing cap
1973 - 1975 Dodge WM300 POWER WAGON... all 1 3/16 inch diameter bearing cap
1994 - 2001 Dodge RAM 1500 with Dana 44... all 1 3/16 inch diameter bearing cap
1994 - 1999 Dodge RAM 2500 with Dana 44... all 1 3/16 inch diameter bearing cap
1974 - 1993 Dodge RAMCHARGER... all 1 3/16 inch diameter bearing cap
1978 - 1996 Ford Bronco all 1 3/16 inch diameter bearing cap
1975 - 1977 Ford F100 Full Time... all 1 3/16 inch diameter bearing cap
1972 - 1977 Ford F100 Part Time... all 1 3/16 inch diameter bearing cap
1976 - 1979 Ford F150 Full Time... all 1 3/16 inch diameter bearing cap
1976 - 1997 Ford F150 Part Time... all 1 3/16 inch diameter bearing cap
1975 - 1979 Ford F250 Full Time with Dana 44... all 1 3/16 inch diameter bearing cap
1978 - 1995 Ford F250 Part Time with Dana 44... all 1 3/16 inch diameter bearing cap
1980 - 1985 Ford F350 Part Time with Dana 44... all 1 3/16 inch diameter bearing cap
1980 - 1997 Ford Ranger ...all 1 3/16 inch diameter bearing cap
1974 - 1980 IHC Scout 800 Series all 1 3/16 inch diameter bearing cap
1974 - 1979 IHC 100, 110, 120, 900, 1000, 1200 Series all 1 3/16 inch diameter bearing cap
1984 - 2001 Jeep Cherokee Compact XJ... all 1 3/16 inch diameter bearing cap
1982 - 1988 Jeep 10 Series...all 1 3/16 inch diameter bearing cap
1974 - 1988 Jeep 20 Series...all 1 3/16 inch diameter bearing cap
1974 - 1981 Jeep 40 Series...all 1 3/16 inch diameter bearing cap
1974 - 1983 Jeep Cherokee Full Size SJ...all 1 3/16 inch diameter bearing cap
1994 - 1999 Jeep Grand Cherokee...all 1 3/16 inch diameter bearing cap
1983 - 1991 Jeep Grand Wagoneer...all 1 3/16 inch diameter bearing cap
1978 - 1983 Jeep Wagoneer...all 1 3/16 inch diameter bearing cap
1984 - 1990 Jeep Wagoneer Compact XJ... all 1 3/16 inch diameter bearing cap
1997 - 2006 Jeep Wrangler TJ... all 1 3/16 inch diameter bearing cap
1993 - 1995 Jeep Wrangler YJ... all 1 3/16 inch diameter bearing cap
Antiguo 17-07-2013, 12:00:34   #3
pato santelices
Avatar de pato santelices
Contactar con pato santelices a través de MSN
Hola cumpita.
Te comento que instale dif. De cheroke en una blazer y no he podido encontrar la cruceta delantera. Será esta que tu tienes la que yo necesito ??? Si tu crees que si me sirve te las compro.
pato santelices está offline   Responder Con Cita
Antiguo 17-07-2013, 18:42:42   #4
CHINO GONZALEZ
Hola Patito.
Tanto tiempo cumpa.
Porque no mides tus crucetas para asegurarte.
El diametro de los cubos que tengo yo deberian ser:
Cubo = 1.188 inches ( 1 3/16 inches )
Antiguo 17-07-2013, 22:22:16   #5
NARANJA MECANICA
Avatar de NARANJA MECANICA
Hola chino!!!!!
Vas al dia nacional del jeepero???
federico
NARANJA MECANICA está offline   Responder Con Cita
Antiguo 17-09-2013, 10:02:02   #6
CHINO GONZALEZ
Aun disponibles.
Acepto ofertas.
La franja horaria es GMT -3. Ahora son las 02:06:43.
