Antiguo 27-07-2005, 16:55:40   #1
andres_kike_lopez
Avatar de andres_kike_lopez
Predeterminado TROLLER..... 4x4 Brazil
WEB http://www.4x4troller.com/
Troller T4 2.8 Turbodiesel is a model of jeep made by Troller Veículos Especiais S/A, and is a 4x4 two-door car with a fibreglass body and steel chassis. It has Clark manual transmission and Dana axles. The engine is MWM 2.8-litre turbodiesel.
Troller Veículos Especiais S/A (Troller) is a manufacturer of automobiles in Brazil. It was founded in 1995, in Horizonte, Ceará.
The name Troller is a non-official Brazilian Portuguese adaptation of the English word troll.
ENGINE
Diesel, MWM, 2.8l Turbo Intercooler,
Torque: 32.7NM at 1,800 rpm,
Net Power: 132 CV at 3,200 RPM,
4 cylinders,
2,800cm3,
Compression rate 19,0:1,
water cooling
Manual accelerator with lock (installed on the panel)
Maximum speed: 155 km/h
SYSTEM AUTOBLOCKING
Track Lock Dana, on the rear axle
GEAR
Manual of high performance (Eaton)
5 forward synchronized gears and 1 reverse gear
Transmission relation:
1st-4.079:1;
2nd-2.289:1;
3rd-1.472:1;
4th-1.000:1;
5th-0.809:1;
Reverse-3.676:1
Transfer Case: Borg Warner
HYDRAULIC GEAR
FREE WHEEL
BRAKES
Disc on the 4 wheels; frontal aired
TRANSMISSION SYSTEM
Selective (4x2, 4x4, reduced) from the total traction by mechanical activation
ELECTRICAL/ILLUMINATION SYSTEM
For civil or military application though selecting key (NATO)
Easy access electrical circuit control general key
Lights and beams equipped with protection fences
Spare battery (12v) for communication system (radio)
External electrical socket for towing signaling system
STRUCTURE
Full body in reinforced fiber glass
Chassis: spars with rectangular section in carbon steel
Suspension: mixed with helicoidally springs and hydraulic buffer on each wheel
Front fence protection in reinforced plastic
Military type rear bumper
Protection against falling and removable doors
Military standard impermeable material hood, coiling windows with transparent mirrors for driver and passenger; transparent and coiling mirrors on the front and rear lateral
Foddable and non-shattering windshield
Seats with military standard covering; adjustable frontal seats, foldable forward and lockable in the desired position; forward foldable back seats and lockable in the desired position
Instrument panel with speedometer, odometer, fuel level and motor water temperature indicators, in addition to the voltmeter and pressure gauge for motor oil pressure
Central panel with foldable fuse box for a better access and boards with specifications � vehicle dimensions, NATO key use instructions and tire pressure for several types of site
WHEELS and TYRES
Wheels: T-6JJ x 16
Tires: 235/85 R16
LINE ACCESSORIES
External support for spare tank, pick-mattock, shovel and vehicle fireman axe
20-liter Spare Tank
Bush-breaker with wire-cutter bar support
Power train protecting plates and fuel tank
Lifting hooks and straps for fastening and towing with grommets for towing safety chain
Metallic Box for tool storage
Allows for vehicle support installation for MG 7.62 and other armaments upon request.
Allows for crane installation with 4,100 kg traction capacity
Military standard rear coupling gear.
DIMENSIONS
Capacity to transport 5 passengers in normal conditions, or four passengers when equipped with military type communication radio.
72-liter fuel tank
Cargo capacity: 530kg
Towing cargo: with brakes � 2.400kg, and without brakes � 750kg
Length: 4.085mmm
Width: 2.080mm
Height: 2.000mm
Between axles: 2.405mm
Free space: 215mm
Weight (in gear order, including full spare tank and other line accessories): 2,190kg
PERFORMANCE
Autonomy over 650 km on paved roads, without spare tank need
Turn minimum ray: 6,00 m to the right and 5.90 m to the left
Input angle: 56�
Output angle: 42� (with installed support towing)
Passage angle: 33�
Maximum Lateral Inclination: 45�
Water Crossing: 800mm � with snorkel: 1 meter
Y TAMBIEN TIENE....
TROLLER PANTANAL
Antiguo 27-07-2005, 17:27:04   #2
GatoMontes
Contactar con GatoMontes a través de MSN
Son bonitos...pero lo que encuentro medio inseguro, ya que son de fibra de vidrio...
Lo extraño es que los brazileros los venden como pan caliente y le dan como caja...
GatoMontes está offline   Responder Con Cita
Antiguo 27-07-2005, 17:43:07   #3
RoNdrigo Pastén
Banned
que vehiculos mas feos...
quiza si le cambiaran esa mascara mejorarian un poco...
Antiguo 27-07-2005, 17:57:14   #4
Pato-Patrol
Los ví en Brasil y me impresionó gratamente lo fuerte que anda ese motor diesel turboalimentado , anda realmente muy bien, le pasa por arriba a varios modelos. :wink:
salutes
Antiguo 27-07-2005, 18:17:59   #5
Esos motores fueron montados en un par de BJ vendidos en brazil y en tras partes del mundo con algunos problemas de culata ..
Antiguo 27-07-2005, 19:24:35   #6
JOTE
Predeterminado Me gustó el verde militar
JOTE
Antiguo 27-07-2005, 20:29:18   #7
Que Trolo !!! :repuke:
Yo creo que un piano Steinway & Sons tiene mas flexion que eso ....
Antiguo 28-07-2005, 02:34:49   #8
FJ40Diesel
Bastante raros esos bichos ... pero debo reconocer que son más bonitos que nuetra versión nacional de "todo terreno".... el mítico Yagán!!
Saludos!
ps: :? me falta otro "intento" chileno de todo terreno..mmmm.... uno militar... pero no me acuerdo el nombre.
FJ40Diesel está offline   Responder Con Cita
Antiguo 29-07-2005, 16:36:22   #9
Rui4x4
A mi me gustaron bastante cuando los vi, me parecen que es una buena base para modificaciones (buenos dif, motor,bloqueo de fabrica, protecciones, etc), y a un precio mucho mas bajo que un wrangler por ejemplo (allá). En cuanto a flexion, no creo que salga algun jeep de fabrica con 80 cm de recorrido de suspension.
Creo que ese mismo motor lo montan en las d22, ranger y L200 alla. Asi que por repuestos no deben tener problemas.
Rui
Rui4x4 está offline   Responder Con Cita
Antiguo 29-07-2005, 17:36:07   #10
Hocicon
Diesel=Water¡¡¡¡¡
4x4 en brazil mario ureta General 12 13-07-2008 18:30:34
Porqué son los 4x4 mejores que las mujeres? Dario_LJ General 4 10-10-2005 16:32:30
www.toyoteros.com.ar lo que encontre "ESPAÑA: NO 4X4 Rudy González General 9 11-08-2005 19:36:56
! ADICTOS AL 4X4..¡ ...PRINCIPALES SINTOMAS...... fango General 33 25-07-2005 17:54:33
5TA FECHA Y FINAL 2004 DE APERRADOS 4X4 hernan urbina Paseos, Raids, Competencias y Eventos 4x4. 2 04-01-2005 20:37:42
La franja horaria es GMT -3. Ahora son las 13:08:26.
