Antiguo 28-02-2004, 14:41:45   #1
Pez Gordo
Avatar de Pez Gordo
Predeterminado Nissan sd 33
Alguien sabe algo sobre este diesel de Nissan , asi como specs y datos utiles , 1200 gracias
Antiguo 28-02-2004, 15:19:50   #2
ullrich
Contactar con ullrich a través de MSN
el motor es excelente en especial para tlc lo importante es que busques el con turbo :P
ullrich está offline   Responder Con Cita
Antiguo 28-02-2004, 22:33:42   #3
Aca va algo del SD33 :
Max. Output: 105 PS at 3800rpm JIS (SAE gross)
Max. Torque: 25kg-m at 2200 rpm JIS (SAE gross)
TYPE: 4-cycle, water-cooled diesel
COMBUSTION: Swirl Chamber
CYLINDERS: 6, in-line, vertical
BORE x STROKE: 83x100mm (3.27x3.94in.)
PISTON DISPLACEMENT: 3246cc
COMPRESSION RATIO: 20.8 : 1
CYLINDER BLOCK
High-strength cast iron with replaceable dry liners.
CYLINDER HEAD
One-piece high-strength cast iron; special cast-iron valve inserts are shrink-fitted.
CRANKSHAFT
Drop-forged steel with balance weights; all main and connecting rod bearing surfaces are induction-hardened.
PISTON AND RINGS
Aluminum alloy piston for high strength, lightweight and good heat conductivity; three compression and two oil control rings are chrome-plated for long service life.
CAMSHAFT
High-quality cast iron; lobes are specially processed to improve hardness and durability.
BEARINGS
Precision type, steel-backed trimetal shell; five main bearings.
VALVES
Overhead valves; one intake and exhaust per cylinder; made of special heat-resistant steel; exhaust valve with stellite-treated surface.
WEIGHT (DRY): Approx. 305 kg
Antiguo 29-02-2004, 12:47:17   #4
Camello tiene un Cruiser con SD33, caja del motor ( patrol ) con coronas 4.88, lo he manejado y es uno de los poquisimos diesel que encuentro se mueve muy bien, hasta en la arena igual se mueve . No tira como un 2F, pero para ser diesel y dar 9 km/l, excelente
Las coronas 4.88 creo k igual hacen algo de la magia.
Antiguo 01-03-2004, 09:49:42   #5
ullrich
y eso quel motor del camello es sin turbo :? :?
Antiguo 01-03-2004, 12:28:10   #6
Empezado por k5ullrich
Un motor bien relacionado es magia .. 226%
Antiguo 01-03-2004, 12:53:57   #7
Pez Gordo
Avatar de Pez Gordo
Tpage sos todo un poeta de las tuercas eh
Antiguo 01-03-2004, 16:38:08   #8
He probado ese motor con turbo en un patrol std del 81 , con neumaticos de 31" andaba muy bien , luego con 33" empezo a faltarle el aire y luego cuando le pusieron 35"... :( bueno ahora le estan cambiando diffs. de TLC con rel 4.11 luego veremos.
SALUDOS
Antiguo 02-03-2004, 00:28:14   #9
Alguien ha oido hablar de un motor Nissan de 3.300 c.c. 4 cilindros sin turbo??...Desconosco cual es la sigla que lo designa.
GRX.
Antiguo 02-03-2004, 11:41:02   #10
SALUDOS
Jummm no creo que en realidad vaya a ser mcuha diferencia, pues muchos diferenciales de patrol venian con 4.11 ya .. otros con 3.70 y otros con 4.32 .. ( las Patrol Pick Ups )
Pero habrá que ver que es lo que están pensando ellos ..
Empezado por Diego Pazols
me sale del alma como la pasión por los TLC ..
jajajajajaj me estoy poniendo romantico .. :wink:
Nissan King Cab 4x4 unica en Chile JPVM Venden - Vehiculos 4X4 132 27-08-2007 21:26:16
Motorn Nissan K24 (Nissan D21 Y Terrano D22) año 1998 (95.000Km.) boelckers Venden - Partes y accesorios para 4X4 8 27-04-2007 19:34:20
Compro espejos electricos Nissan Terrano Alik Compran 0 10-01-2007 22:23:21
Nissan Titan V8 = USA agarrate los pantalones JPVM General 4WD 17 31-12-1969 21:00:00
CHEVY ZR2 vs NISSAN DIESEL Giovanni General 14 31-12-1969 21:00:00
La franja horaria es GMT -3. Ahora son las 10:56:08.
