Antiguo 31-12-1969, 21:00:00   #31
Predeterminado Algun Fanatico del 4x4 RC ??
RC= Radio controlado
Estoy cotizando a una gente que se instalo en Chile y que vende estas maravillas. Motor a explosion y traccion 4x4 .... Savage 21
Hay alguien aca que le pegue al tema ?
Las caracteristicas son impresionantes:
- Giant 1/8th scale (16.8" x 21")
- Factory assembled
- Full-time shaft driven four-wheel drive
- Complete set of rubber sealed ball bearings
- TF-4 3-channel super narrowband radio system
- High torque steering servo (rated at 70 oz./in. & .20 sec. speed @ 4.8v (4 cells) or 90 oz./in. & .16 sec. speed @ 6.0v (5 cells))
- Nitro Star 21 BB engine (ABC) with 7mm slide carburetor
- Purple aluminum heatsink engine head
- Composite tuned pipe and aluminum rear exhaust header
- Cast aluminum heavy-duty engine mount
- Heavy-duty drivetrain and suspension optimized for .21 engine
- Hardened metal differential gears
- Heavy-duty steel dogbones
- Adjustable 2 speed transmission with heavy-duty metal internal gears
- Adjustable slipper clutch
- Adjustable fiberglass disc brake
- Wide-track suspension (nearly 17 inches wide!)
- Stainless steel inboard hinge pins with anodized aluminum braces
- 8 long stroke oil-filled coilover shock absorbers
- Rigid aluminum TVP chassis (Twin Vertical Plates)
- Large 160cc fuel tank with primer
- Enclosed radio box for protection of electronics
- Front and rear skidplate bumpers
- Pre-painted trimmed GT-1 truck body with decals applied
- Adjustable body posts (with extra mount for SUV bodies)
- Chrome 5 spoke wheels and all-terrain tires (with inner foam)
Antiguo 31-12-1969, 21:00:00   #32
Sorry por el tamaño :
http://www.hpiracing.com/graphics/catalog2k3/06-07.jpg
Antiguo 31-12-1969, 21:00:00   #33
Empezado por Negro XJ
Pero pato to no cachai cuanto salen esas (%&#@)...pq la dura estan muy weno...y si hay alguien que los distribuya en schile.....
sldops
Les tengo la pomada, es una tienda como bien dijo Arturo, o Caita ? esta frente al nuevo Mall de La Dehesa, se llama www.hobbycity.cl. Me cotizaron la Savage .21 en $ 475.000 completa con radio control tal como sale en las fotos, opcionales tiene miles, pero hay que comprar el modulo de reversa. Forma de pago con tarjeta y cheques (varios). Es un kit "ready to run" , traccion 4x4, amoriguadores hidraulicos coilovers, 2 velocidades, con motor Novarossi de ... agárrnse los pantalones .... 2.4 HP , se imaginan como anda esta cosa ??????????
Ahora, en USA valia US$ 800 y esta rebajada ahora a US$ 399,99 ... casualmente mi cuñado que vive en Miami viene en Noviembre
Antiguo 31-12-1969, 21:00:00   #34
Alfred, soy un newbee completo en el tema (ahora teniendo uno ... ) pero no se que mezcla es , dice nitrometano, puede ser metanol como usan muchos, parece que tambien lo venden en las tiendas éstas.
A todo esto el motor Novarossi de 2.1cc dice que produce 2.4 Hp @ 29.500 rpm !! es proporcionalmente V8 350 cu.i desarrollando 6.700 HP eso si que es sacarle el jugo a un motor .-
Antiguo 31-12-1969, 21:00:00   #35
Ahora si que estamos jodidos .. carajo de un hobbie caro a sumarle otro caro, por que es metira que van a dejar de meterle cosas a los 4X4 de verdad o .. si .. :?
Yo comencé con eso antes del Off Road en carros de verdad, quizas más adelante vuelva .. pero ahora prefiero ir yo montado y pasar la raja iendo a lugares que otros no pueden ..
Antiguo 23-10-2003, 19:18:24   #36
-ArtSerey-
AK ESTA MI JUGETITO
...sorry por lo sucio , luego subo fotos limpio
traktorke
Antiguo 23-10-2003, 19:32:13   #37
HAKUNA
Empezado por -ArtSerey-
AK ESTA MI JUGETITO
Antiguo 24-10-2003, 01:49:35   #38
-ArtSerey-
Empezado por HAKUNA
AK ESTA MI JUGETITO
traktorke
Antiguo 24-10-2003, 01:50:30   #39
-ArtSerey-
Empezado por HAKUNA
AK ESTA MI JUGETITO
porque chucha no se ven???
traktorke
Antiguo 24-10-2003, 01:56:55   #40
-ArtSerey-
Empezado por HAKUNA
AK ESTA MI JUGETITO
porque (%&#@) no se ven???
una mano pa' que se vean porfa
traktorke
hilux 90 4x4 D/C (yugo del.) Jorge Heuser Venden - Vehiculos 4X4 11 18-07-2007 20:19:11
Calendario Actividades ZONA TUERCA en Movicenter 2005 Marcelobarahona Paseos, Raids, Competencias y Eventos 4x4. 26 04-09-2005 04:58:58
El 123 del 4x4 OB1 Novatos 12 04-08-2005 22:31:12
algun dato para traer un 4x4 desde santiago a antofagasta jor General 1 30-07-2005 21:24:43
ALGUNA NOVEDAD 4X4 PARA EL SALON DEL AUTOMOVIL ?????? JCPA General 5 21-10-2004 15:04:59
La franja horaria es GMT -3. Ahora son las 10:04:05.
