Antiguo 18-03-2008, 23:32:43   #1
Juan Pablo Clon
Avatar de Juan Pablo Clon
Predeterminado Calibrar velocimetro AutoMeter
Estimados necesito programar el velocimetro, que sale en la foto para que mida adecuadamente, según lo que me dijeron hay que resetearlo andar 3,2KM y volver a presionar el botón, aparentemente algo estoy haciendo mal porque no me a funcionado, agradeceria detallar los pasos a seguir para dejarlo funcionando ok.
http://store.summitracing.com/partde...0&autoview=sku
Antiguo 18-03-2008, 23:39:12   #2
Walter Werner
Predeterminado Re: Calibrar velocimetro AutoMeter
HOLA juan pablo tu y tus INTRUNENTOS LOCOS
SALUDOS
WALTER WERNER
Walter Werner está offline   Responder Con Cita
Antiguo 19-03-2008, 00:19:04   #3
Del sitio Autometer ...
Electronic Speedometer calibration made easy!
To calibrate your electronic speedometer:
1) With the power off, push and hold the calibration button (trip/reset button when equipped). While holding the button, start the vehicle and continue to hold the button until the pointer sweeps to full scale and stays at full scale. You may now release the button.
2) Drive to the beginning of a pre-marked 2 mile distance and come to a stop. It does not matter how far away it is to get to this pre-marked 2 mile distance. Do NOT shut the engine off. Push and release the button. The pointer will drop to half scale.
3) Drive the 2 mile distance. The pointer will remain at the half scale mark no matter what speed you drive. If the speedometer has a LCD display odometer, it will be normal to see it counting rapidly as it is receiving a speed signal. If you have to stop during the calibration, that is o.k.. The speedometer is simply counting pulses during this time.
4) At the end of the 2 mile distance, come to a complete stop and push and release the button. The pointer will drop to 0 and the calibration is stored. You are now finished.
Remember the accuracy of your 2 mile distance will directly affect the accuracy of your speedometer.
Antiguo 19-03-2008, 00:22:20   #4
Juan Pablo Clon
Empezado por JPVM Ver Mensaje
Tocayo, me dejaste igual, jajajajaja, pegate una traducida, ya que el ingles no es mi fuerte, saludos...
Antiguo 19-03-2008, 00:36:03   #5
Empezado por Juan Pablo Clon Ver Mensaje
1) Con el motor apagado, aprieta y manten apretado el boton de calibracion. Mientras aprietas el boton, enciende el motor y manten apretado hasta que la aguja llegue hasta el tope de la escala. Ahora suelta el boton.
2) Maneja hasta el principio de un trecho pre marcado de 3.2 kmt y para. No importa que este trecho este lejos de tu casa. No pares el motor. Aprieta y suelta el boton. La aguja va a caer a la mitad de la escala.
3) Maneja ese trecho de 3.2 kmt. La aguja se va a mantener en la mitad de la escala independiente de la velocidad que manejes. Si tienes un odometro digital veras que los numeros pasan rapido cuando el instrumento reciba una señal. Si en ese trecho debes detenerte no importa, el marcador esta contando pulsos en ese tiempo.
4) Al final del trecho de 3.2 kmt detente por completo. Aprieta y suelta el boton nuevamente. La aguja caera a 0 y la calibracion sera guardada. Estas listo.
La precision del marcador sera dependiente de cuan exacto midas ese trecho de 3.2 kmt.... ojo.
Antiguo 19-03-2008, 01:28:28   #6
Juan Pablo Clon
Muchas gracias, ahi te cuento como me va, te pasaste!.
Antiguo 19-03-2008, 09:08:11   #7
Llámalo servicio de post venta tocallo ... total yo te vendi esas maravillas que nunca instalé ...
Antiguo 19-03-2008, 09:53:57   #8
Roland
Avatar de Roland
Que buena JP..... eso es servicio post venta
Antiguo 19-03-2008, 14:43:24   #9
Asi es mi amigo Roland , aca habemos varios en TA que no recibimos calificaciones positivas pero que actuamos siempre en bajo perfil haciendo las cosas como corresponde.-
Antiguo 20-03-2008, 09:25:45   #10
AndR3Z
así de simple?
como marcai las 2 millas?
kennedy?
La franja horaria es GMT -3. Ahora son las 16:06:54.
