La Berta
Avatar de La Berta
Predeterminado TBI SWAP LINKS
Aqui hay algunos links de
Inyecciones con partes GM
algo de lo que he recopliado.........
http://www.bgsoflex.com/megasquirt.html
http://www.customefis.com./
http://www.force-efi.com/
http://www.mortec.com/
hay varios mas
.......se que hay varios especialistas en busacr info .....a ver que encuantran
La Berta
Avatar de La Berta
Maybe the best all around EFI site on the world wide web!!!
WWW.SDSEFI.COM
Do-It-Yourself Fuel Injection
DIY-EFI
Fellow DIY-EFI List Subscribers
http://www.aces.edu/~gparmer/efi/
GM ECM Diagnostic Software
You'll need an ALDL cable for the following diagnostic programs. I sell them or you can build them yourself. Email me for more info.
WinALDL - the Windows 160 Baud ALDL Reader! Awesome Free Product for TBI ECMs!!!
Craig Moates ALDL Software Free TPI Scantool Software for MAF and Speed Density ECMs !!!
TTS Power Systems DataMaster Software Downloads Page
Diacom
GM ECM Tuning Software
TunerCat
WINBIN
GM ECM EPROM Programming Equipment
This is the least expensive EPROM programmer I have found.
Cheapest EPROM Programmer
For an EPROM eraser, see my site. I sell a low cost EPROM eraser as good as any out there.
Programming GM ECM EPROMs
www.ThirdGen.Org
Custom Programmed Performance Chips
Westers Garage
www.FastChip.com
MustGoFasterRacing
General EFI Software
Home Dyno
GM ECM Technical Info
BCC Lookup at GMECM
My 85 Z28 and Changing a '165 ECM to a '730
TuneItUp's LT1_Edit - The Editor for your '94/'95 LT1 Motor
TEP - Thrasher Engineered Performance - Performance parts for your 3800
Ludis's Home Page
CM's Z28
GM EFI Parts
Pioneer Standard | Distributor of Transportation Components
EFI Parts
Dakota Digital Car Audio, Instrumentation, & Accessories Homepage
Racing Fuel Injectors - RC Engineering
i-5 Automotive.com - Home -
GM EFI Misc. Sites
Syclone & Typhoon Home Page
The CrossFire Injection Vault
CustomEFIS Direct Competitors
DON'T FORGET TO COMPARE APPLES TO APPLES - Note what you get and don't get for the price.
Howell-EFI
Affordable Fuel Injection
Speartech Fuel Injection Systems
www.cruzinperformance.com
Other EFI Sites
MSD IGNITION FUEL MANAGEMENT
ACCEL EMIC
Jims Performance
TPIS Home Page
Fuel Injection Specialties - HomePage
RANCEFI.COM
Arizona Speed and Marine - 480-753-0208
Speed-Pro® Electronics Menu
Pectel Control Systems Ltd.
PerfectPower
White Racing
www.034efi.com
General Engine Tuning
High Performance Tuning
Wide Band O2 Sensor Tuning Aids
DIY Wide Band O2 Project
Lambdaboy WB O2 Sensor
FJO Automotive
EGORTECH
Misc. Sites
BOB, the Bottom Of the Bottle Oil Recovery System
Lehi Sheet Metal
PerTronix Performance Products
5-SPEED GETRAG TRANSMISSION
www.highperformancecars.com
Instalar Motor 5.7 VORTEC 1997 RAUL VEGA General 4WD 19 19-09-2016 18:23:10
4 links posicion de links awayo R/C Off Road 0 19-11-2008 21:24:17
Proyecto 2F - TBI (EFI) FLOZANO Proyectos 4x4 227 18-08-2008 11:18:18
VENDIDO-> Inyeccion TBI Completa para V8 5.7 Chevy MLOZANO Venden - Partes y accesorios para 4X4 19 28-02-2007 22:50:19
Problema en 350 TBI VSilva General 4WD 8 20-02-2006 23:33:03
La franja horaria es GMT -3. Ahora son las 08:00:18.
